Re: no install [message #1792696 is a reply to message #1792686] |
Sun, 22 July 2018 10:50 |
joerg holland Messages: 3 Registered: July 2018 |
between installing eclipse i got that lot of errors, but splash starts, i hit php-photon and it installed, started and i used it.
now,next day i got that:
after click eclipse in startmenu:
OpenJDK 64-Bit Server VM warning: Ignoring option MaxPermSize; support was removed in 8.0
and ....
!SESSION Sun Jul 22 12:44:21 CEST 2018 -----------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2018-07-22 12:44:21.992
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:466)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:566)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:626)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
..what i have to install, change, whatever ... ?
[Updated on: Sun, 22 July 2018 11:40] Report message to a moderator
Re: no install [message #1793265 is a reply to message #1793241] |
Thu, 02 August 2018 11:55 |
Did you install or change anything in between days? Other than the Eclipse version,
you haven't given any details to work off of.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.10778 seconds
