Home » Newcomers » Newcomers » git diff and .cproject and character (.cproject)
git diff and .cproject and character [message #1792657] Fri, 20 July 2018 14:45 Go to next message
Steve Iribarne is currently offline Steve IribarneFriend
We use MCUXpresso which is based off of Eclipse Oxygen 3a.
We have IOS users, Windows 10 Users and Linux Users. I'm noticing that every time I just open MCUXpresso that when I do a `git diff` that I have a bunch of at the end of "some" of the lines.
I believe that is some sort of new line, but I'm not sure where to turn this off/on or whatever I need to do to turn that off.
Can someone please point me to a config setting that I'm obviously missing.
Thanks.
-stv
Re: git diff and .cproject and character [message #1792679 is a reply to message #1792657] Sat, 21 July 2018 06:25 Go to previous message
With Oomph we have a Git clone task, and we make sure that we always set the core autocrlf property to true:
https://git.eclipse.org/c/jgit/jgit.git/tree/org.eclipse.jgit/src/org/eclipse/jgit/lib/ConfigConstants.java#n54
https://git.eclipse.org/c/jgit/jgit.git/tree/org.eclipse.jgit/src/org/eclipse/jgit/lib/ConfigConstants.java#n125
https://git.eclipse.org/c/jgit/jgit.git/tree/org.eclipse.jgit/src/org/eclipse/jgit/lib/CoreConfig.java#n63
Perhaps some details here will help you understand why that's important:
https://stackoverflow.com/questions/2825428/why-should-i-use-core-autocrlf-true-in-git
I believe this property can be set in your global Git configuration in the file system, assuming EGit finds that. In any case, you can configure it globally in Window -> Preferences -> Team -> Git -> Configuration as well.
If you see these undesirable line ending differences on Linux already, you have already checked Windows-style line endings into your repository. You will need to "repair" your repository by recommitting those files with proper Linux-style endings.
You might want to consider creating an Oomph Project setups for your team so that the whole process of creating a properly configured development environment is automated:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring
You can see examples how such a setup is used here:
https://ci.eclipse.org/emf/
and here:
https://wiki.eclipse.org/Eclipse_Platform_SDK_Provisioning
Ed Merks
Previous Topic:Access restriction
Next Topic:eclipse-cpp-neon-3-win32-x86_64
Current Time: Sat Mar 25 17:37:13 GMT 2023
Powered by FUDForum. Page generated in 0.03599 seconds
