Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Rate limiter blocks?
Rate limiter blocks? [message #1792597] Fri, 20 July 2018 04:48 Go to next message
Rafi Zulfahmi is currently offline Rafi ZulfahmiFriend
Dear all,
I work on some projects where i need to adapt some scheme from Matlab's simulink to 4DIAC's function blocks from.
But currently, i can't find some blocks that i need.
A blocks that i can't seems to find is some kind of rate limiter to limit the rate of changes of input signal to some value between a specified slew rate and fall rate. I only find some blocks that limits the value of input itself to some specified value
The second blocks that i can't find is a polynomial blocks, when i need to put some input signal to solve some polynomials.
Is these blocks available on the 4DIAC? I use 1.8.4 for now.
Thankyou.
Re: Rate limiter blocks? [message #1792602 is a reply to message #1792597] Fri, 20 July 2018 06:47 Go to previous messageGo to next message
Martin Melik-Merkumians is currently offline Martin Melik-MerkumiansFriend
Member
Hi Rafi,
no such FBs are not available afaik.
Martin
Re: Rate limiter blocks? [message #1792728 is a reply to message #1792602] Mon, 23 July 2018 09:50 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
but we are happy to add such to our library if you can provide them to us.
Also please if possible upate to the latest 4diac 1.9.1 (soon 1.9.2). 1.8.4 is now more then 1.5 years old.
Alois
Re: Rate limiter blocks? [message #1792785 is a reply to message #1792728] Tue, 24 July 2018 04:31 Go to previous messageGo to next message
Thankyou for the answers Prof. Alois and mr . Martin
Here is the information about the library that i search https://www.mathworks.com/help/simulink/slref/ratelimiter.html
i'm very grateful if it can be added. I'll try to develop it too if i can
About the versions, I've installed the 1.9.1 before, but some of the libraries that i need is seemingly isn't available anymore (OSCAT) in the current versions, so i downgraded to 1.84.
[Updated on: Tue, 24 July 2018 04:32]
Report message to a moderator
Re: Rate limiter blocks? [message #1792787 is a reply to message #1792785] Tue, 24 July 2018 05:32 Go to previous messageGo to next message
we are currently not sure how we'll proceed with OSCAT. But you can use the 1.8.4 OSCAT also in 1.9.x. You just need to copy the fbt files into your projet's typelib and to copy the FORTE module into the new forte.
Re: Rate limiter blocks? [message #1792847 is a reply to message #1792787] Wed, 25 July 2018 04:09 Go to previous messageGo to next message
I see, i'll try it soon.
Thankyou for the support sir.
Re: Rate limiter blocks? [message #1792868 is a reply to message #1792847] Wed, 25 July 2018 09:08 Go to previous message
you are welcome.
Previous Topic:Project Import 4Diac and JAVA version
Next Topic:download boot file to the target which is running forte
Current Time: Fri Oct 23 08:42:23 GMT 2020
Powered by FUDForum. Page generated in 0.01938 seconds
