Home » Modeling » QVT-OML » QVTo transformation from command line
QVTo transformation from command line [message #1792433] Tue, 17 July 2018 23:42 Go to next message
ashrafur rahman is currently offline ashrafur rahmanFriend
There are many posts about this topic in this forum. I tried all of them without any success.
I want to run qvto from the terminal without eclipse.
I tried this:
https://wiki.eclipse.org/QVTOML/Examples/InvokeInJava
But it shows the following error:
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/ocl/EvaluationHaltedException
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
	at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
	at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	at org.eclipse.m2m.qvt.oml.TransformationExecutor.<init>(TransformationExecutor.java:86)
	at comrun.main(comrun.java:26)
Caused by: java.lang.ClassNotFoundException: org.eclipse.ocl.EvaluationHaltedException
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	... 14 more
Re: QVTo transformation from command line [message #1792437 is a reply to message #1792433] Wed, 18 July 2018 05:19 Go to previous messageGo to next message
You say you want to run QVTo from the command line. I am not aware of a standard main() so that is not supported. There is an Ant task that I don't recommend.
You reference an example that is for standalone execution and indeed that seems to be what you you are doing with comrun.main. This approach is fully supported.
The NoClassDefFoundError looks like a standard Java bad-classpath bug. Setting these up is difficult, you either just add them iteratively and rediscover the path with each new Eclipse release, or use the MANIFEST.MF to do it for you - really easy.
In your case, the standard message tells you that the JAR containing org.eclipse.ocl.EvaluationHaltedException is not on the classpath. (It is the org.eclipse.ocl plugin).
Ed Willink
Re: QVTo transformation from command line [message #1792444 is a reply to message #1792437] Wed, 18 July 2018 07:11 Go to previous messageGo to next message
Thanks for the reply. I will try to add each path iteratively.
Re: QVTo transformation from command line [message #1792447 is a reply to message #1792444] Wed, 18 July 2018 07:29 Go to previous messageGo to next message
You really should use the MANIFEST. Manually you have to specify the fully-qualified JARs which is really tedious and unstabvle. THe MANIFEST works it all out for you.
Ed Willink
Re: QVTo transformation from command line [message #1792448 is a reply to message #1792447] Wed, 18 July 2018 07:41 Go to previous messageGo to next message
Perhaps https://bugs.eclipse.org/bugs/show_bug.cgi?id=537126 addresses your use case.
Ed Willink
Re: QVTo transformation from command line [message #1792452 is a reply to message #1792448] Wed, 18 July 2018 08:19 Go to previous messageGo to next message
Thanks a lot for showing the right direction. I try to do it with MANIFEST file. Actually, I am facing multiple problems, while trying to run in standalone mode. Can you please give me any working example for qvto which runs in standalone mode?
Re: QVTo transformation from command line [message #1792469 is a reply to message #1792452] Wed, 18 July 2018 10:31 Go to previous messageGo to next message
You might get some ideas from:
http://git.eclipse.org/c/mmt/org.eclipse.qvtd.git/tree/tests/org.eclipse.qvtd.doc.bigmde2016.tests/src/org/eclipse/qvtd/doc/bigmde2016/tests/qvto/BigMDE2016QVToTests.java
(and its sibling files). Only complexity is that it uses ProjectMap to make URIs uniform.
Ed Willink
Re: QVTo transformation from command line [message #1792490 is a reply to message #1792469] Wed, 18 July 2018 15:18 Go to previous messageGo to next message
Thank you so much. I will check it.
Re: QVTo transformation from command line [message #1800126 is a reply to message #1792490] Thu, 20 December 2018 09:43 Go to previous messageGo to next message
Gururaj Maddodi is currently offline Gururaj MaddodiFriend
I'm actually having the same issue. The example looks very promising, but I do not have the ProjectMap package in my Eclispe installation. Could you point as to where I can download the Plugin or the update site.
The plugin from here https://www.eclipse.org/modeling/mdt/downloads/?project=ocl doesn't seem to have the org.eclipse.ocl.pivot.internal.resource.ProjectMap package.
Thanks.
Re: QVTo transformation from command line [message #1800142 is a reply to message #1800126] Thu, 20 December 2018 12:01 Go to previous message
Oh yes it does. It is in the org.eclipse.ocl.pivot plugin that is installed when you install the examples and editors.
Also: https://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/plugins/org.eclipse.ocl.pivot/src/org/eclipse/ocl/pivot/internal/resource/ProjectMap.java
Ed Willink
Previous Topic:Eclipse QVTo latest P2 repos
Next Topic:Compilation errors found in unit when calling QVTo transform
Current Time: Tue Feb 18 15:19:38 GMT 2020
Powered by FUDForum. Page generated in 0.01997 seconds
