Home » Modeling » TMF (Xtext) » LanExpressions
Re: LanExpressions [message #1792267 is a reply to message #1792265] |
Fri, 13 July 2018 16:29 |
this is not a expression problem.
Atomic returns Expression:
var=[VariableDef] |
val=[ConstDef] |
{IntConstant} value=INT |
{StringConstant} value=STRING
is parsed as
var=ID |
val=ID |
which is ambigous
=> you have 2 options
(1) introduce a diffent syntax for var and val references
(2) unify them into one reference
varorval=[VariableOrConstDef] |
VariableOrConstDef: VariableDef | ConstDef;
Twitter : @chrdietrich
Re: LanExpressions [message #1792299 is a reply to message #1792267] |
Sun, 15 July 2018 16:44 |
Christoff Erasmus Messages: 32 Registered: December 2016 |
Member |
@Christian Dietrich, thanks for pointing out "VariableOrConstDef". Oops... My bad, silly mistake.
But, my problems are not yet over. :( . Refer to Parsing Errors below.
I have spent some time and:
1) Tried to debug the language using AntlrWorks,
as suggested by https://blogs.itemis.com/en/debugging-xtext-grammars-what-to-do-when-your-language-is-ambiguous.
To be honest, debugging of the Language got the better of me. I really need some help, thus Point (2) below.
2) Created a github project for my version of ExpressionDSL (github project link)
3) Created some initial Unit tests for the expected Parsing, refer ExpressionDSLParsingTest.xtend
4) Quick link to ExpressionDSL.xtext language definition
Request:
Please guide me on how to change the ExpressionDSL.xtext, to be able to succesfully pass the ExpressionDSLParsingTest.xtend unit tester.
Maven Install Error Log (extract):
Running org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest
log4j:WARN No appenders could be found for logger (org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser).
log4j:WARN Please initialize the log4j system properly.
Tests run: 15, Failures: 8, Errors: 0, Skipped: 0, Time elapsed: 1.59 sec <<< FAILURE! - in org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest
testExpressionOr(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.434 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:5 missing '(' at 'bC', XtextSyntaxDiagnostic: null:5 missing ')' at ';', XtextSyntaxDiagnostic: null:6 missing '(' at 'bB', XtextSyntaxDiagnostic: null:6 missing '(' at 'bC', XtextSyntaxDiagnostic: null:6 missing ')' at ';', XtextSyntaxDiagnostic: null:7 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing '(' at 'bB', XtextSyntaxDiagnostic: null:8 missing ';' at 'or', XtextSyntaxDiagnostic: null:8 missing ')' at 'bC', XtextSyntaxDiagnostic: null:8 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 mismatched input '<EOF>' expecting ')'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionOr(ExpressionDSLParsingTest.java:248)
testExpressionComparison(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.023 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:23 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:24 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:25 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:26 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:27 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:28 extraneous input '(' expecting ')'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionComparison(ExpressionDSLParsingTest.java:353)
testExpressionUnaryPlusOrMinus(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.019 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:1 mismatched input ':' expecting ';', XtextSyntaxDiagnostic: null:11 no viable alternative at input '-', XtextSyntaxDiagnostic: null:12 no viable alternative at input '+', XtextSyntaxDiagnostic: null:14 no viable alternative at input '-', XtextSyntaxDiagnostic: null:15 no viable alternative at input '+', XtextSyntaxDiagnostic: null:17 no viable alternative at input '-', XtextSyntaxDiagnostic: null:18 no viable alternative at input '+', XtextSyntaxDiagnostic: null:21 no viable alternative at input '-', XtextSyntaxDiagnostic: null:21 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:22 no viable alternative at input '+', XtextSyntaxDiagnostic: null:22 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:23 no viable alternative at input '-', XtextSyntaxDiagnostic: null:23 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:23 no viable alternative at input 'iA', XtextSyntaxDiagnostic: null:23 no viable alternative at input 'iB', XtextSyntaxDiagnostic: null:23 no viable alternative at input ')', XtextSyntaxDiagnostic: null:23 extraneous input ')' expecting ';', XtextSyntaxDiagnostic: null:25 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:26 mismatched input '(' expecting ';'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionUnaryPlusOrMinus(ExpressionDSLParsingTest.java:441)
testDeclarations(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.005 sec
testExpressionAtomic(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.005 sec
testFuncationCall01(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.003 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:2 no viable alternative at input ')'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testFuncationCall01(ExpressionDSLParsingTest.java:80)
testFuncationCall02(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.005 sec
testExpressionExponent(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0 sec
testExpressionAnd(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.012 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:5 missing '(' at 'bC', XtextSyntaxDiagnostic: null:5 missing ')' at ';', XtextSyntaxDiagnostic: null:6 missing '(' at 'bB', XtextSyntaxDiagnostic: null:6 missing '(' at 'bC', XtextSyntaxDiagnostic: null:6 missing ')' at ';', XtextSyntaxDiagnostic: null:7 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing '(' at 'bB', XtextSyntaxDiagnostic: null:8 missing ';' at 'and', XtextSyntaxDiagnostic: null:8 missing ')' at 'bC', XtextSyntaxDiagnostic: null:8 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 mismatched input '<EOF>' expecting ')'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionAnd(ExpressionDSLParsingTest.java:280)
testExpressionPrecedence(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0 sec
testAssignment01(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.014 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:23 mismatched input '=' expecting '(', XtextSyntaxDiagnostic: null:23 missing ';' at 'testfuncNoParmsReturnsINT', XtextSyntaxDiagnostic: null:23 no viable alternative at input ')', XtextSyntaxDiagnostic: null:24 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:25 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:26 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:27 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:28 mismatched input '(' expecting ';'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testAssignment01(ExpressionDSLParsingTest.java:172)
testExpressionFunctionExp(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.007 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:9 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:9 no viable alternative at input 'cA', XtextSyntaxDiagnostic: null:10 no viable alternative at input 'NOT', XtextSyntaxDiagnostic: null:10 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:10 no viable alternative at input 'cA', XtextSyntaxDiagnostic: null:12 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:14 mismatched input '(' expecting ';'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionFunctionExp(ExpressionDSLParsingTest.java:482)
testExpressionMulOrDiv(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0 sec
testExpressionBinaryPlusOrMinus(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0 sec
testExpressionPrimary01(org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest) Time elapsed: 0.008 sec <<< FAILURE!
java.lang.AssertionError: Unexpected errors: XtextSyntaxDiagnostic: null:6 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 missing ';' at 'bA', XtextSyntaxDiagnostic: null:8 missing '(' at 'not', XtextSyntaxDiagnostic: null:8 missing '(' at 'and', XtextSyntaxDiagnostic: null:8 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing ')' at ';', XtextSyntaxDiagnostic: null:9 missing '(' at 'and', XtextSyntaxDiagnostic: null:9 missing '(' at 'not', XtextSyntaxDiagnostic: null:9 mismatched input ')' expecting '(', XtextSyntaxDiagnostic: null:9 missing ')' at ';', XtextSyntaxDiagnostic: null:10 missing '(' at 'or', XtextSyntaxDiagnostic: null:10 missing '(' at 'bB', XtextSyntaxDiagnostic: null:10 missing ';' at 'and', XtextSyntaxDiagnostic: null:10 mismatched input 'not' expecting ')', XtextSyntaxDiagnostic: null:10 missing ')' at 'bC', XtextSyntaxDiagnostic: null:10 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:12 mismatched input 'bA' expecting ')', XtextSyntaxDiagnostic: null:12 no viable alternative at input '=', XtextSyntaxDiagnostic: null:12 mismatched input 'not' expecting ')', XtextSyntaxDiagnostic: null:12 missing ')' at ';', XtextSyntaxDiagnostic: null:13 mismatched input '(' expecting ')'
at org.xtext.example.expressiondsl.tests.ExpressionDSLParsingTest.testExpressionPrimary01(ExpressionDSLParsingTest.java:522)
Results :
Failed tests:
ExpressionDSLParsingTest.testAssignment01:172 Unexpected errors: XtextSyntaxDiagnostic: null:23 mismatched input '=' expecting '(', XtextSyntaxDiagnostic: null:23 missing ';' at 'testfuncNoParmsReturnsINT', XtextSyntaxDiagnostic: null:23 no viable alternative at input ')', XtextSyntaxDiagnostic: null:24 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:25 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:26 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:27 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:28 mismatched input '(' expecting ';'
ExpressionDSLParsingTest.testExpressionAnd:280 Unexpected errors: XtextSyntaxDiagnostic: null:5 missing '(' at 'bC', XtextSyntaxDiagnostic: null:5 missing ')' at ';', XtextSyntaxDiagnostic: null:6 missing '(' at 'bB', XtextSyntaxDiagnostic: null:6 missing '(' at 'bC', XtextSyntaxDiagnostic: null:6 missing ')' at ';', XtextSyntaxDiagnostic: null:7 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing '(' at 'bB', XtextSyntaxDiagnostic: null:8 missing ';' at 'and', XtextSyntaxDiagnostic: null:8 missing ')' at 'bC', XtextSyntaxDiagnostic: null:8 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 mismatched input '<EOF>' expecting ')'
ExpressionDSLParsingTest.testExpressionComparison:353 Unexpected errors: XtextSyntaxDiagnostic: null:23 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:24 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:25 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:26 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:27 extraneous input '(' expecting ')', XtextSyntaxDiagnostic: null:28 extraneous input '(' expecting ')'
ExpressionDSLParsingTest.testExpressionFunctionExp:482 Unexpected errors: XtextSyntaxDiagnostic: null:9 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:9 no viable alternative at input 'cA', XtextSyntaxDiagnostic: null:10 no viable alternative at input 'NOT', XtextSyntaxDiagnostic: null:10 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:10 no viable alternative at input 'cA', XtextSyntaxDiagnostic: null:12 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:14 mismatched input '(' expecting ';'
ExpressionDSLParsingTest.testExpressionOr:248 Unexpected errors: XtextSyntaxDiagnostic: null:5 missing '(' at 'bC', XtextSyntaxDiagnostic: null:5 missing ')' at ';', XtextSyntaxDiagnostic: null:6 missing '(' at 'bB', XtextSyntaxDiagnostic: null:6 missing '(' at 'bC', XtextSyntaxDiagnostic: null:6 missing ')' at ';', XtextSyntaxDiagnostic: null:7 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing '(' at 'bB', XtextSyntaxDiagnostic: null:8 missing ';' at 'or', XtextSyntaxDiagnostic: null:8 missing ')' at 'bC', XtextSyntaxDiagnostic: null:8 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 mismatched input '<EOF>' expecting ')'
ExpressionDSLParsingTest.testExpressionPrimary01:522 Unexpected errors: XtextSyntaxDiagnostic: null:6 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:8 missing ';' at 'bA', XtextSyntaxDiagnostic: null:8 missing '(' at 'not', XtextSyntaxDiagnostic: null:8 missing '(' at 'and', XtextSyntaxDiagnostic: null:8 missing '(' at 'bC', XtextSyntaxDiagnostic: null:8 missing ')' at ';', XtextSyntaxDiagnostic: null:9 missing '(' at 'and', XtextSyntaxDiagnostic: null:9 missing '(' at 'not', XtextSyntaxDiagnostic: null:9 mismatched input ')' expecting '(', XtextSyntaxDiagnostic: null:9 missing ')' at ';', XtextSyntaxDiagnostic: null:10 missing '(' at 'or', XtextSyntaxDiagnostic: null:10 missing '(' at 'bB', XtextSyntaxDiagnostic: null:10 missing ';' at 'and', XtextSyntaxDiagnostic: null:10 mismatched input 'not' expecting ')', XtextSyntaxDiagnostic: null:10 missing ')' at 'bC', XtextSyntaxDiagnostic: null:10 mismatched input ';' expecting '(', XtextSyntaxDiagnostic: null:12 mismatched input 'bA' expecting ')', XtextSyntaxDiagnostic: null:12 no viable alternative at input '=', XtextSyntaxDiagnostic: null:12 mismatched input 'not' expecting ')', XtextSyntaxDiagnostic: null:12 missing ')' at ';', XtextSyntaxDiagnostic: null:13 mismatched input '(' expecting ')'
ExpressionDSLParsingTest.testExpressionUnaryPlusOrMinus:441 Unexpected errors: XtextSyntaxDiagnostic: null:1 mismatched input ':' expecting ';', XtextSyntaxDiagnostic: null:11 no viable alternative at input '-', XtextSyntaxDiagnostic: null:12 no viable alternative at input '+', XtextSyntaxDiagnostic: null:14 no viable alternative at input '-', XtextSyntaxDiagnostic: null:15 no viable alternative at input '+', XtextSyntaxDiagnostic: null:17 no viable alternative at input '-', XtextSyntaxDiagnostic: null:18 no viable alternative at input '+', XtextSyntaxDiagnostic: null:21 no viable alternative at input '-', XtextSyntaxDiagnostic: null:21 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:22 no viable alternative at input '+', XtextSyntaxDiagnostic: null:22 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:23 no viable alternative at input '-', XtextSyntaxDiagnostic: null:23 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:23 no viable alternative at input 'iA', XtextSyntaxDiagnostic: null:23 no viable alternative at input 'iB', XtextSyntaxDiagnostic: null:23 no viable alternative at input ')', XtextSyntaxDiagnostic: null:23 extraneous input ')' expecting ';', XtextSyntaxDiagnostic: null:25 mismatched input '(' expecting ';', XtextSyntaxDiagnostic: null:26 mismatched input '(' expecting ';'
ExpressionDSLParsingTest.testFuncationCall01:80 Unexpected errors: XtextSyntaxDiagnostic: null:2 no viable alternative at input ')'
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] org.xtext.example.expressiondsl.parent 1.0.0-SNAPSHOT SUCCESS [ 0.660 s]
[INFO] org.xtext.example.expressiondsl .................... SUCCESS [ 34.906 s]
[INFO] org.xtext.example.expressiondsl.ide ................ SUCCESS [ 3.808 s]
[INFO] org.xtext.example.expressiondsl.ui ................. SUCCESS [ 5.581 s]
[INFO] org.xtext.example.expressiondsl.target ............. SUCCESS [ 0.036 s]
[INFO] org.xtext.example.expressiondsl.tests .............. FAILURE [ 11.577 s]
[INFO] org.xtext.example.expressiondsl.ui.tests 1.0.0-SNAPSHOT SKIPPED
[INFO] BUILD FAILURE
Re: LanExpressions [message #1792302 is a reply to message #1792299] |
Sun, 15 July 2018 18:12 |
i find it hard to "help" with such general questions. you should solve the stuff issue by issue.
one thing i dont understand is e.g.
is your grammar case insensitive if yes you have to tell xtext that
i dont understand your FunctionExp thingy
i dont understand functioncall
i dont understand your semicolon concept
i dont understand your unary expressions. usual pattrn is
UnaryExpression: MINUS Primary | Primary;
Primary: '(' Expressions ')' | Atom;
[Updated on: Sun, 15 July 2018 18:47] Report message to a moderator
Re: LanExpressions [message #1792307 is a reply to message #1792302] |
Sun, 15 July 2018 22:59 |
Member |
Thanks for your valuable input.
Christian Dietrich
Yes, it is suppose to be case insensitive. Fixed the mwe2 workflow.
Christian Dietrich
This my a temp at catering for the "user-defined functions" in the Expressions Precedence.
This is a pain point, that I am struggling to get right.
Christian Dietrich
The grammar is suppose to be procedural.
The procedure call, may or may not return a value.
1) Thus to cater for the procedure call returns a value, and to comply with the Expressions Precedence.
I created the "VariableAssignment" rule that references expressions of which the "FunctionExp"ression rule is part off.
===> variable = functioncall();
2) To cater for when the procedure call does not return a value, nor is part of an Assignment expression.
I created the "FunctionCall" rule.
===> functioncall();
Christian Dietrich
Currently, All the statements should be terminated by semicolons ";".
Christian Dietrich
Thanks for the suggestion, but would this not "break" the expected Expressions Precedence when creating the AST?
Conclusion:
The Expressions Precedence is a Pain in my ass, and I am clearly not implementing it correctly.
But my understanding is that to get the AST correct for later processing, I need to define the "Expression" rule correctly
Questions:
1) How critical is building the AST to comply with the Precedence rules?
2)Should I rather manipulate the AST after parsing has been done?
References:
https://www.ibm.com/support/knowledgecenter/ssw_ibm_i_73/rzasd/opprec.htm
https://www.ibm.com/support/knowledgecenter/ssw_ibm_i_73/rzasd/expropt.htm
/* Expressions Precedence:
* --> Built-in functions, user-defined functions
* --> unary +, unary -, NOT
* --> binary +, binary -
* --> AND
* --> OR
[Updated on: Sun, 15 July 2018 23:00] Report message to a moderator
Re: LanExpressions [message #1792316 is a reply to message #1792307] |
Mon, 16 July 2018 04:54 |
I mean:
why dont you dist. function call and function call statement. and fix functionexpr
FunctionCallStatement:
call=FunctionCall ";"
FunctionCall:
name=[FunctionDef]
(params+=Expression (':' params+=Expression)*)?
UnaryPlusMinusOrNot returns Expression:
({UnaryPlus}'+' right=FunctionExp | {UnaryMinus}'-' right=FunctionExp) | ('NOT' right=FunctionExp)
) |FunctionExp;
FunctionExp returns Expression:
Primary | (
(func=FunctionCall)
Current Time: Thu Mar 28 10:37:46 GMT 2024
Powered by FUDForum. Page generated in 0.05558 seconds
