Home » Eclipse Projects » GlassFish Tools » Unable to install Glassfish plugin on Eclipse Photon & Oxygen(Unable to install Glassfish plugin on Eclipse Photon & Oxygen)
Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792116] Wed, 11 July 2018 19:40 Go to next message
Nicole Ang is currently offline Nicole AngFriend
index.php/fa/33365/0/I'm trying to set up the Glassfish server on Eclipse but have had no luck. I'm on Java version 10.0.1
Steps:
1. Open Eclipse
2. Go to Help > Eclipse Marketplace
3. Search for GlassFish
4. Click on Install
5. Glassfish Tools and oracle.eclipse.tools.glassfish is selected. Click Confirm.
Result:
Installation progress bar says "Cannot perform operation. Computing alternate solutions, may take awhile." It eventually finishes and says "Cannot complete the request. See error logs for details."
Not sure where to find the error logs. I get this same error on both Eclipse Photon & Oxygen.
index.php/fa/33367/0/
index.php/fa/33368/0/
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792125 is a reply to message #1792116] Thu, 12 July 2018 04:31 Go to previous messageGo to next message
We too would need to see the error log for details. Type "Error Log" in the "Quick Access" search box to the upper right of the perspective for the view of the error log.
Ed Merks
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792155 is a reply to message #1792125] Thu, 12 July 2018 08:29 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
If you don't have an Error Log view, the file itself is at <workspace location>/.metadata/.log . The view would only be present if you had the Plug-in Development Environment installed.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1792240 is a reply to message #1792116] Fri, 13 July 2018 06:21 Go to previous messageGo to next message
Jayesh Patel is currently offline Jayesh PatelFriend
I have faced the same issue with Eclipse Photon 4.8.0
Attached the error log.
  • Attachment: ErrorLog.txt
    (Size: 12.63KB, Downloaded 782 times)
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1793839 is a reply to message #1792116] Thu, 16 August 2018 20:16 Go to previous messageGo to next message
Bradford Lumley is currently offline Bradford LumleyFriend
Any closer to figuring this out? I'm having the same issue. Error log attached.
  • Attachment: log.txt
    (Size: 25.03KB, Downloaded 276 times)
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1794241 is a reply to message #1793839] Mon, 27 August 2018 23:05 Go to previous messageGo to next message
Nei Alcantara Jr is currently offline Nei Alcantara JrFriend
I have the same problem. Any news on that?
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1795067 is a reply to message #1792116] Thu, 13 September 2018 22:50 Go to previous messageGo to next message
Jonathon Ewen is currently offline Jonathon EwenFriend
I too am unable to download glassfish tools from the eclipse marketplace in Oxygen or Photon. It works in Neon.
Are we any closer to a resolution?
I found a post about a similar issue in the past regarding a broken web cache for the marketplace?
community.oracle.com/thread/3933198
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1797004 is a reply to message #1792116] Tue, 23 October 2018 22:59 Go to previous messageGo to next message
Alessandro Volcich is currently offline Alessandro VolcichFriend
Is there any news on this? I'm experiencing the same problem in Eclipse for Java EE 4.9
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800229 is a reply to message #1797004] Fri, 21 December 2018 15:00 Go to previous messageGo to next message
Ian Spencer is currently offline Ian SpencerFriend
Having the same problem with Eclipse Luna. Running on Windows10.
In addition to this, there is no link on the Server view, where you can add additional servers.
index.php/fa/34548/0/
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800767 is a reply to message #1800229] Tue, 08 January 2019 03:03 Go to previous messageGo to next message
Prateek Tripathi is currently offline Prateek TripathiFriend
I am using Eclipse 2018 12.I am trying to install GlassFish 5.0 using eclipse marketplace(under help) but the option available only supports GlassFish4.x.
Can anyone help ?
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1800768 is a reply to message #1800767] Tue, 08 January 2019 03:10 Go to previous messageGo to next message
As you are on the latest, you might try http://download.eclipse.org/glassfish-tools/1.0.0/repository ,
the Update Site for the tools now that they are a project at the Eclipse Foundation. Work with that URL from the Help->Install New Software menu in Eclipse.
Nitin Dahyabhai
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1805050 is a reply to message #1800768] Fri, 05 April 2019 01:01 Go to previous messageGo to next message
Armand Welsh is currently offline Armand WelshFriend
Nitin Dahyabhai wrote on Mon, 07 January 2019 22:10
This worked for eclipse 2018-09 and 2018-12, but no longer works with 2019-03. I tried to submit a bug report, but that is blocked. Eclipse Foundation manages GlassFish now. How about we either restore the ability to install the version published to the marketplace, and fix the one in the official eclipse.org link.
Anyone?
Error:
Cannot complete the install because one or more required items could not be found.
Software being installed: GlassFish Tools 1.0.0.201806111515 (org.eclipse.glassfish.tools.feature.group 1.0.0.201806111515)
Missing requirement: GlassFish Tools 1.0.0.201806111515 (org.eclipse.glassfish.tools.feature.group 1.0.0.201806111515) requires 'org.eclipse.equinox.p2.iu; org.eclipse.sapphire.feature.group [9.1.0,10.0.0)' but it could not be found
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1805051 is a reply to message #1800768] Fri, 05 April 2019 01:02 Go to previous messageGo to next message
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1809360 is a reply to message #1805050] Sun, 14 July 2019 19:39 Go to previous messageGo to next message
You'll need to add the Sapphire update site, http://download.eclipse.org/sapphire/9.1.1/repository , to your list of Available Software Sites so that it can be found.
Nitin Dahyabhai
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1809442 is a reply to message #1809360] Tue, 16 July 2019 09:18 Go to previous messageGo to next message
Alex Gambler is currently offline Alex GamblerFriend
You guys are my rescuers, I had a similar problem for several days, I did everything exactly with your advice and now everything is fine.
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1836887 is a reply to message #1809442] Sun, 17 January 2021 19:28 Go to previous messageGo to next message
ikbel ben is currently offline ikbel benFriend
I was struggling a lot to find a sol, thus I decided to uninstall eclipse Oxygene and install Eclipse neon it works fine now, https://www.eclipse.org/downloads/packages/release/neon/3
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1838627 is a reply to message #1836887] Tue, 02 March 2021 16:16 Go to previous messageGo to next message
A solution was found for current releases, though. Why go back to 4 year old releases?
Nitin Dahyabhai
Re: Unable to install Glassfish plugin on Eclipse Photon & Oxygen [message #1844333 is a reply to message #1792116] Thu, 09 September 2021 13:52 Go to previous message
Kisan Behera is currently offline Kisan BeheraFriend
Please follow the below steps for configuration of Glass-Fish Server With Eclipse IDE.
Go to the Help Section Of Eclipse.
Choose Option Install New Software.
Paste the below given link in the Text Box of Work With option.
Link: http://download.eclipse.org/glassfish-tools/1.0.1/repository/
Then Proceed with Confirm OK OK.
Now It will take some time to install and automatically ask for Restart.
Success.
Current Time: Mon Sep 27 04:40:28 GMT 2021
Powered by FUDForum. Page generated in 0.02823 seconds
