Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Making ROS Work on Forte Master Branch(How to make ROS work on master branch?)
Making ROS Work on Forte Master Branch [message #1792080] Wed, 11 July 2018 03:29 Go to next message
Victor Hartanto is currently offline Victor HartantoFriend
Thread Closed.
Duplicated. Here:
https://www.eclipse.org/forums/index.php/t/1094068/
[Updated on: Thu, 19 July 2018 03:22]
Report message to a moderator
Re: Making ROS Work on Forte Master Branch [message #1792134 is a reply to message #1792080] Thu, 12 July 2018 06:05 Go to previous messageGo to next message
Martin Melik-Merkumians is currently offline Martin Melik-MerkumiansFriend
Member
I would guess your compiler error is due to a type hierarchy change in CommFB/BaseCommFB and has not been fixed entirely.
I will take a look on it. Could you please file a bug?
Martin
Re: Making ROS Work on Forte Master Branch [message #1792521 is a reply to message #1792134] Thu, 19 July 2018 03:16 Go to previous message
@Martin,
Thank you so much for the reply. You could follow up this topic on the other thread.
[Updated on: Thu, 19 July 2018 03:18]
Previous Topic:[SOLVED] Request validation FB according to standard
Next Topic:Problems with Client blocks in 4DIAC -Matlab communication
Current Time: Mon Oct 19 22:34:50 GMT 2020
Powered by FUDForum. Page generated in 0.01813 seconds
