Home » Modeling » EMF » Xcore 2.14 vs Workspace vs. standalone
Xcore 2.14 vs Workspace vs. standalone [message #1792060] Tue, 10 July 2018 16:29 Go to next message
Christian Dietrich is currently offline Christian DietrichFriend
i try to evaluate the xcore and emf maven plugins karsten is producing right now.
i am getting the following validation message on a minimal sample model
[ERROR] ERROR:The feature 'modelDirectory' of 'Model' contains a bad value. The path '/xcore-maven-example/src/main/java-gen' must contain at least two valid segments to denote a workspace folder;  (file:/home/dietrich/git/xcore-maven-example/src/main/resources/model.xcore line : 3 column : null)
@GenModel(
    bundleManifest="false",
    modelDirectory="/xcore-maven-example/src/main/java-gen",
    complianceLevel="8.0"
package sample.model
class User {
    String name
    op String sayHello(User user) {
        "Hello " + user.name
@Ed any idea? should this validation be executed in standalone mode at all?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792063 is a reply to message #1792060] Tue, 10 July 2018 16:36 Go to previous messageGo to next message
Here is an example
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792067 is a reply to message #1792063] Tue, 10 July 2018 18:35 Go to previous messageGo to next message
This is produced by org.eclipse.emf.codegen.ecore.genmodel.util.GenModelValidator.validatePath_WellFormedPath(String, DiagnosticChain, Map<Object, Object>) and it's been this way for a long time. Of course I don't know why the validator is being called. Is something going to try to generate this model standalone?
Ed Merks
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792069 is a reply to message #1792067] Tue, 10 July 2018 18:44 Go to previous messageGo to next message
yes. my code does that and people that use the xtext maven (or gradle plugin) to generate java from xcore do that too.
problem was not there in 2.12. the validator has a @since 2.14
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792070 is a reply to message #1792069] Tue, 10 July 2018 18:57 Go to previous messageGo to next message
in the last version that is at maven central (2.12) there is no such validation method
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792072 is a reply to message #1792069] Tue, 10 July 2018 19:03 Go to previous messageGo to next message
I found quite a few latent bugs like this once the OCL builder started (optionally) validating *.ecore and *.uml; the new EAnnotationValidators are the cause.
Xtext is often quite enthusiastic at validating so this is probably an Xtext rather than OCL tooling 'improvement'.
I recall difficulties ensuring that the standalone registrations were correct, but I think that enough of the problems were fixed to make it useable. https://bugs.eclipse.org/bugs/show_bug.cgi?id=528869 references some relevant difficulties.
See also org.eclipse.ocl.examples.xtext.tests.TestUtil.initializeEcoreEAnnotationValidators() and https://bugs.eclipse.org/bugs/show_bug.cgi?id=528371
Ed Willink
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792073 is a reply to message #1792072] Tue, 10 July 2018 19:28 Go to previous messageGo to next message
the validation was introduced with the path edatatype with https://github.com/eclipse/emf/commit/9a4b553ffbf1a2fe60cd1660231f82bab7177afc
Re: Xcore 2.14 vs Workspace vs. standalone [message #1792074 is a reply to message #1792073] Tue, 10 July 2018 19:36 Go to previous message
created https://bugs.eclipse.org/bugs/show_bug.cgi?id=536883
Previous Topic:[EMF Validation] No maintainer of project?
Next Topic:[xcore][xtend]
Current Time: Thu Oct 01 12:22:00 GMT 2020
Powered by FUDForum. Page generated in 0.02018 seconds
