Hiding column via script [message #1791989] |
Mon, 09 July 2018 11:25 |
Alexander Scott Messages: 6 Registered: July 2018 |
I am having a random size resultset returned. I have managed to programatically create a table of X width. What I now need to do is add a visibility expression to hide the column when there is no data.
Can anyone give me a hand? I assume I need to add some sort of "visibility" property with an expression as the value?
What I have so far;
importPackage( Packages.org.eclipse.birt.report.model.api );
reportContext.setPersistentGlobalVariable("COLUMN_SIZE", "20");
var COLUMN_SIZE = reportContext.getPersistentGlobalVariable("COLUMN_SIZE");
reportDesignHandle = reportContext.getReportRunnable().designHandle.getDesignHandle();
elementFactory = reportDesignHandle.getElementFactory();
dataSetHandle = elementFactory.newScriptDataSet( "Data Set" );
dataSetHandle.setDataSource( "Data Source" );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
// public TableHandle newTableItem(String name, int columnNum, int headerRow, int detailRow, int footerRow) {
table = elementFactory.newTableItem( "table1", COLUMN_SIZE, 1, 1, 0 );
table.setWidth( "80%" );
table.setProperty( "dataSet", "Data Set" );
computedSet = table.getColumnBindings();
for ( var i = 0; i < COLUMN_SIZE; i++ ) {
cs1 = StructureFactory.createComputedColumn();
cs1.setName(i);
if (i == 2) {
cs1.setExpression( "false" );
cs1.setFilterExpression( "true" );
cs1.setProperty("visibility", "false");
} else {
cs1.setExpression( "dataSetRow[" +i +"]" );
expression = new Expression("valueExpr", "false");
cs1.setExpressionProperty("visibility", expression); // does not work
computedSet.addItem( cs1 );
// Header
myheader = table.getHeader( ).get( 0 );
tcell = myheader.getCells( ).get( i );
mylabel = elementFactory.newLabel( i );
mylabel.setText( "H" + i );
tcell.getContent( ).add( mylabel );
// detail
mydetail = table.getDetail( ).get( 0 );
tcell = mydetail.getCells( ).get( i );
mydata = elementFactory.newDataItem( null );
mydata.setResultSetColumn(i);
tcell.getContent( ).add( mydata );
if (cs1.getName() == "two") {
tcell == null
reportDesignHandle.getBody( ).add( table );
FUDForum. Page generated in 0.03215 seconds
