Re: Eclipse crashes System [message #1792473 is a reply to message #1792426] |
Wed, 18 July 2018 11:54 |
Florian Bauer Messages: 4 Registered: July 2018 |
Hello
Tauno Voipio wrote on Tue, 17 July 2018 16:54So the problem does not have anything to do with STM32?
Yes, it has nothing to do with STM32.
Please open your Eclipse CDT and go to Help -> Help Contents -> C/C++ Development User Guide -> Before you begin, and follow the instructions there.
I followed the steps in the Getting Started Guide.
As I mentioned before I can succesfully create a "Hello World"-Project, build and run it.
Only when I try to debug it, the whole system freezes.
Pictures of my debug-Settings are attached to my first post.
I'm not sure if the problem lies in the debug configuration but it even crashes when I create a "Hello World"-project and use only the default settings.
On another system creating a "Hello-World"-project, building, running and debugging it, without changing any of the configurations works perfectly fine.
So my guess would be that there is some kind of global setting which causes this error. But unfortunately I have no idea where to look.
If it is of any help:
The freeze occurs when the debugging loading scale on the bottom right corner reaches 96%.
Thank you for your help.
Florian
FUDForum. Page generated in 0.24379 seconds
