Home » Eclipse Projects » Rich Client Platform (RCP) » AspectJ seems to conflict with YourKit
AspectJ seems to conflict with YourKit [message #1791351] Thu, 28 June 2018 10:07 Go to next message
madamx x is currently offline madamx xFriend
I am using AspectJ load-time weaving for advice classes (eg, Spring declarative transactions and other uses). When I start the application for profiling (via eclipse 3.2.1) I get a ClassFormatError for any classes that has been advised. This problem was not present in 5.5.
In the example below, the class error for the aspect itself (using @Aspect style). But I get the same error for any class that is weaved.
Are there any YK settings that might work around this issue, as it is effectively blocking the use of YK?
thanks!
Re: AspectJ seems to conflict with YourKit [message #1792049 is a reply to message #1791351] Tue, 10 July 2018 13:53 Go to previous message
Brian de Alwis is currently offline Brian de AlwisFriend
Odd as your post is an exact duplicate of the initial post on the YourKit forums dating from 2006:
https://www.yourkit.com/forum/viewtopic.php?p=3477
The issue was fixed in a subsequent version of AspectJ. The previous thread and the following seem to have some workaround.
https://yourkit.com/forum/viewtopic.php?f=3&t=2472
Brian.
Previous Topic:e4xmi view appearance changes on eclipse
Next Topic:plugin_customization.ini file not loaded during first time launch
Current Time: Fri Dec 03 23:34:02 GMT 2021
Powered by FUDForum. Page generated in 0.02390 seconds
