Home » Eclipse Projects » EGit / JGit » How Can I ignore files when using ArchiveCommand(Ignoring file/s in ArchiveCommand)
How Can I ignore files when using ArchiveCommand [message #1790886] Tue, 19 June 2018 15:25 Go to next message
Guillermo Coscarelli is currently offline Guillermo CoscarelliFriend
I would like to ignore some files (in particular what the .gitignore says) when executing an ArchiveCommand.
I see no options in the API. Any idea or workaround?
Thanks.
Re: How Can I ignore files when using ArchiveCommand [message #1791201 is a reply to message #1790886] Mon, 25 June 2018 22:03 Go to previous message
Thomas Wolf is currently offline Thomas WolfFriend
As far as I see the ArchiveCommand works on the content as checked in into the git repository, so .gitignored files should never be in the archive. To exclude checked-in files, you could use ArchiveCommand.setPaths() with an array of repository-relative paths giving the files to include.
Previous Topic:Repository and project show ^nnn to represent commits not pushed, even after hard reset
Next Topic:ssh connection using an ECDSA key fails on second attempt (auth failed)
Current Time: Mon Jan 20 07:03:35 GMT 2020
Powered by FUDForum. Page generated in 0.01668 seconds
