Home » Modeling » TMF (Xtext) » OneOf
OneOf [message #1790616] Wed, 13 June 2018 15:14 Go to next message
David Horacek is currently offline David HoracekFriend
for few days I'm still struggling with the basics of grammar, so I hope someone can help me out.
I' trying very simple example of constants and variables:
const a = 1;
const b = "asd";
var c = "asd";
var d = a;
var e = c;
The Grammar I've come up with looks like this:
Domainmodel: (elements+=Type)*;
terminal FLOAT: ('+' | '-')? INT ('.' (INT)?)?;
PrimitiveValue: value=(STRING|FLOAT);
Type:
	ConstantDeclaration | VariableDeclaration
ConstantDeclaration:
	'const' name=ID '=' value=PrimitiveValue ';'
VariableDeclaration:
	'var' name=ID ('=' value=[VariableValue])? ';'
VariableValue:
	PrimitiveValue | VariableReference
VariableReference:
	(ref=[VariableDeclaration] | ref=[ConstantDeclaration])
Error says that the problem is two possible results... which I guess comes from VariableReference where ConstantDeclaration can fit into both because it fits inside value property of VariableDeclaration? ... I'm not really sure though.
Can someone please explain it a little bit more in depth or provide and example how to write a grammar for such language case?
Thanks in advance.
Re: OneOf [message #1790821 is a reply to message #1790616] Mon, 18 June 2018 14:38 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
the problem is
ref=[VariableDeclaration] is short for ref=[VariableDeclaration|ID] which says: refer to VariableDeclaration, parse ID
so it is parsed as if there is a ref=ID
so in your case
VariableReference:
(ref=ID | ref=ID)
which is obviously ambigious
=> you either need to disabigue the both syntax wise or you need to make the one reference
VariableReference:
(ref=[Type])
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:Keyword/name=ID conflicts
Next Topic:Syntax Error in lambda implementing Xtext quickfixes
Current Time: Wed Oct 20 12:40:08 GMT 2021
Powered by FUDForum. Page generated in 0.01995 seconds
