Home » Modeling » EMF » [CDO] View update timing/concurrency
[CDO] View update timing/concurrency [message #1790463] Mon, 11 June 2018 12:14 Go to next message
Robert Schulk is currently offline Robert SchulkFriend
Member
I was wondering what happens in this case:
* A class has two containment references x and y
* An object of this class is viewed by one client with a CDOView
* The object's references are both modified from another client by a CDOTransaction and a single commit.
Now let's say the viewing client exports the object to XML exactly during the update. Would it be possible that the exported file contains the changes for reference "x" but not for reference "y"?
Also, am I correct to assume that this is definitely prevented by using CDOView#syncExec?
Re: [CDO] View update timing/concurrency [message #1790474 is a reply to message #1790463] Mon, 11 June 2018 13:26 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Remote updates are incorporated into a local model by the invalidator thread of the view like so:
    synchronized (getViewMonitor())
      lockView();
      try
        doInvalidateSynced(invalidationData);
      finally
        unlockView();
If you don't want your model access be interrupted by the invalidator thread you should use CDOView.syncExec, which is implemented as follows:
  public void syncExec(Runnable runnable)
      lockView();
      try
        runnable.run();
      finally
        unlockView();
Re: [CDO] View update timing/concurrency [message #1790480 is a reply to message #1790474] Mon, 11 June 2018 14:56 Go to previous message
Member
Sounds good, thanks!
I also wrote a small test with which I could -not- generate any inconsistent state.
Previous Topic:[EReference] How to change its referred EClass
Next Topic:Dynamic Enumeration-based Attributes
Current Time: Sat Oct 19 17:41:29 GMT 2019
Powered by FUDForum. Page generated in 0.01655 seconds
