Home » Modeling » TMF (Xtext) » The ?= operator
The ?= operator [message #1790412] Sat, 09 June 2018 18:16 Go to next message
In this grammar:
MessageSchema:
    schema=SchemaDeclaration
    types=TypeDeclarations
SchemaDeclaration:
    'schema' name=QName 'id' '=' id=INT 'version' '=' version=INT optionalAttrs=OptionalSchemaAttrs?;
OptionalSchemaAttrs:
    ('headerType' '=' headerType=QName)? (bigEndian ?= 'bigEndian');
TypeDeclarations:
    'types' '{' simpleTypes+=SimpleTypeDeclaration+ '}';
I want to allow for 2 optional items to the schema declaration, which I have put in rule OptionalSchemaAttrs: a header type and a switch for flipping to big endian (default is little).
The result is not exactly what I want: if I don't include header type, the presence/absence of keyword 'bigEndian' works as expected:
// this is ok:
schema org.sbelang.examples.v2.ExampleSchema
	id = 1 version = 1
// this is also ok:
	id = 1 version = 1 bigEndian
But if I include a header type, the keyword 'bigEndian' becomes mandatory:
// this is ok:
	id = 1 version = 1
 	headerType = a.b.c.D
	bigEndian
types {
// this is NOT ok:
	id = 1 version = 1
types {
The last example gives gives me the error: missing 'bigEndian' at 'types'.
According to the docs:
The ?= sign (boolean assignment operator) expects a feature of type EBoolean and sets it to true if the right hand side was consumed, independently from the concrete value of the right hand side.
I don't understand how the presence of headerType affects the requirement for keyword 'bigEndian' to be consumed after it?
Re: The ?= operator [message #1790413 is a reply to message #1790412] Sun, 10 June 2018 00:56 Go to previous messageGo to next message
?= only says. Assign the left hand side Boolean attribute with true if the righthand side is present.
=> you grammar is wrong
The usual pattern is
Myflag?="mykw"?
Re: The ?= operator [message #1790416 is a reply to message #1790413] Sun, 10 June 2018 03:43 Go to previous messageGo to next message
Ok, I must say that even now looking at the docs, this was not apparent to me. Thanks you.
Re: The ?= operator [message #1790420 is a reply to message #1790413] Sun, 10 June 2018 05:41 Go to previous messageGo to next message
I've understood the issue and fixed it, but I still can't wrap my head around the fact that the right hand side must explicitly be made optional (like you pointed out, I was assuming it implicitly is).
So what is the use case for not making the right hand side optional? Can you give me an example grammar where ?= would assign false (when the right hand side is NOT optional)? Or is it practically useless, but just the way things are?
I'm just trying to make sure I understand the utility scope of this operator.
Re: The ?= operator [message #1790422 is a reply to message #1790420] Sun, 10 June 2018 06:41 Go to previous message
Think of this grammar snippet
Flag?="true" |"false"
Previous Topic:Xtext Serialization: how to benchmark?
Next Topic:Working with INT optional features - default value feature
Current Time: Thu Jul 17 06:18:13 EDT 2025
Powered by FUDForum. Page generated in 0.07847 seconds
