Home » Newcomers » Newcomers » Eclipse no longer launches.
Eclipse no longer launches. [message #1790365] Fri, 08 June 2018 15:40 Go to next message
When I try launch eclipse, its show the splash screen. Then it asks where I would like to have my workspace, after selecting that it shows a dialog that states that it has failed to lauch and I should check the log file.
I have had a look at the log file, but I can't make out what the log file is saying. I have tried deleting the workspace and the eclipse folder and then rextracting it. This has not helped.
I am running Ubuntu 18.
I did have eclipse installed and working earlier using umake, but decided I would rather just do it "manually" so I uninstalled umake and deleted the files related to eclipse from that installation.
Here is the output from the log file:
!SESSION 2018-06-08 17:30:35.042 -----------------------------------------------
eclipse.buildId=4.7.3.M20180330-0640
java.version=10.0.1
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_ZA
Framework arguments:  -product org.eclipse.epp.package.cpp.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.osgi 4 0 2018-06-08 17:30:44.963
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
	... 23 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
	... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-06-08 17:30:45.040
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
	at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
	at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
	at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
	at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
	at org.eclipse.osgi.container.Module.doStop(Module.java:634)
	at org.eclipse.osgi.container.Module.stop(Module.java:498)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
	at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
	... 21 more
Any help as to how to fix this would be much appreciated.
Re: Eclipse no longer launches. [message #1790367 is a reply to message #1790365] Fri, 08 June 2018 16:32 Go to previous messageGo to next message
You shouldn't need to https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 with that version, but it seems like you do.
Re: Eclipse no longer launches. [message #1790371 is a reply to message #1790367] Fri, 08 June 2018 17:12 Go to previous message
Thanks that worked!
Previous Topic:Pre Authentication on jetty server
Next Topic:EGit could not detect where Git is installed
Current Time: Tue Feb 11 09:48:02 GMT 2025
Powered by FUDForum. Page generated in 0.04322 seconds
