Home » Modeling » TMF (Xtext) » How to fetch value from my text
How to fetch value from my text [message #1790324] Fri, 08 June 2018 07:37 Go to next message
I have my grammar which looks like this :
DataType2:
'DataType2' name=ID
'DataTypeRef' DataTypeRef = ( BasicType | OwnType )
BasicType : Basic8 | Basic16 | BasicBool ;
Basic8 :{Basic8 } "unit9";
Basic16 :{Basic16 } "unit18";
BasicBool :{BasicBool} "boolean";
OwnTypes : referenced=[TypeX| QualifiedName];
TypeX: BasicDataType;
Now when user can write a file with the above data :
DataType2 abc {
DataTypeRef unit18 //(here i get a dropdown with values "unit9,unit18,bool" )
till here everything is fine ...:)
now I want to fetch the "unit8" from the file in my back-end.
How to get this value from the user file, as I am not able to fetch the value from the object?
Re: How to fetch value from my text [message #1790325 is a reply to message #1790324] Fri, 08 June 2018 07:39 Go to previous messageGo to next message
i do not understand your question.
myDataType2.getDataTypeRef() should give you an instance of Basic16
Re: How to fetch value from my text [message #1790330 is a reply to message #1790325] Fri, 08 June 2018 07:51 Go to previous messageGo to next message
Yes, it is giving the instance of Basic16 but form that object I am not able to retrieve unit18.
Re: How to fetch value from my text [message #1790332 is a reply to message #1790330] Fri, 08 June 2018 07:53 Go to previous messageGo to next message
i dont understand what you mean. do you have multiple different Basic16 ?
if not the mapping is 1:1
if yes you should have a different grammar e.g.
Basic16 :{Basic16 } value="unit18";
Re: How to fetch value from my text [message #1790333 is a reply to message #1790332] Fri, 08 June 2018 07:56 Go to previous messageGo to next message
No, I have only 1 basic16
Re: How to fetch value from my text [message #1790335 is a reply to message #1790333] Fri, 08 June 2018 07:57 Go to previous message
you can change it anyway
Previous Topic:Controlling generator behavior with parameters
Next Topic:Generate code with Xtend of ReqIF model
Current Time: Thu Jul 17 22:00:39 EDT 2025
Powered by FUDForum. Page generated in 0.08186 seconds
