Re: Papyrus does not recognize the types from an UML Profile [message #1790451 is a reply to message #1790439] |
Mon, 11 June 2018 09:53 |
Missing name Mising name Messages: 25 Registered: February 2010 |
First of all, thx for the answer and forgive my lack of knowledge but I don't understand...
I registered my profile to my model as you can see from the following screenshot
but on the 'import registered my profile does not appear'(as you can see from screen shots....)
I developed UML Profile in another Eclipse Project (while I am planning to re-use this profile for other model) is this the reason I can't see the profile. Does the UML Profile has to developed in the same Eclipse Project?
As I said previously, in the previous version of Papyrus I can access the types defined in profiles without any problem and my code generation mechanisms can still access the profile but the Papyrus UI.
Again thx for answers....
Edit: Is this document is still actual? Papyrus Profile I did every step defined there and I can't still see my profile in the list of registered profiles.
[Updated on: Tue, 12 June 2018 11:34] Report message to a moderator
FUDForum. Page generated in 0.03980 seconds
