Home » Eclipse Projects » Eclipse Platform » Problem with key bindings on newly-opened document
Problem with key bindings on newly-opened document [message #334188] Fri, 23 January 2009 18:44 Go to next message
Originally posted by: billev2k.gmail.com
I have a plugin for editing certain files. The plugin hooks the global undo and
redo commands, and has a couple of its own key bindings. Mostly, things work as
expected.
However, when I double click a file in a project, the file opens, but key
bindings don't work. I can edit the file, then press Ctrl+Z to undo, and focus
changes to the View that had focus before my editor, and the undo doesn't
happen. Same thing with my own key bindings; focus switches to the previous view.
But, if I click on another editor tab, then back to my newly-opened tab, the
keys are routed properly.
Also, if I leave my document open, close & restart Eclipse, the keys are routed
properly.
Any suggestions?
I'm running Eclipse 3.4.1 on Ubuntu 8.10.
Bill Evans
Re: Problem with key bindings on newly-opened document [message #334192 is a reply to message #334188] Sun, 25 January 2009 10:42 Go to previous message
I think your best bet is to open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Previous Topic:Duplicate plug-in entries in "Plug-in Details"
Next Topic:filetransfer ...
Current Time: Sat Apr 26 08:39:09 EDT 2025
Powered by FUDForum. Page generated in 0.03406 seconds
