Xtext scope [message #1790015] |
Sat, 02 June 2018 22:34  |
Hello
I am trying to learn Xtext by studying existing projects.
I am trying to make a project that uses the Sculptor framework xtext.
The xtext dsl is:
* Copyright 2013 The Sculptor Project Team, including the original
* author or authors.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
grammar org.sculptor.dsl.Sculptordsl with org.eclipse.xtext.common.Terminals
generate sculptordsl "http://sculptor.org/dsl/sculptordsl"
DslModel :
(imports+=DslImport)*
app=DslApplication;
DslImport :
'import' importURI=STRING;
DslApplication :
(doc=STRING)?
(("Application" name=ID "{"
"basePackage" "=" basePackage=DslJavaIdentifier) |
("ApplicationPart" name=ID "{"))
(modules+=DslModule)*
DslModule :
(doc=STRING)?
"Module" name=ID "{"
(external?="external")?
("basePackage" "=" basePackage=DslJavaIdentifier )?
("hint" "=" hint=STRING)?
((services+=DslService) |
(resources+=DslResource) |
(consumers+=DslConsumer) |
(domainObjects+=DslSimpleDomainObject))*
DslService :
(doc=STRING)?
"Service" name=ID "{"
((gapClass?="gap") | (noGapClass?="nogap"))? &
("hint" "=" hint=STRING)? &
(webService?="webservice")? &
(subscribe=DslSubscribe)?
(dependencies+=DslDependency)*
(operations+=DslServiceOperation)*
DslResource :
(doc=STRING)?
"Resource" name=ID "{"
(scaffold?="scaffold")? &
("path" "=" path=STRING)?
(dependencies+=DslServiceDependency)*
(operations+=DslResourceOperation)*
DslConsumer :
(doc=STRING)?
"Consumer" name=ID "{"
("unmarshall to" ("@")?messageRoot=[DslDomainObject])?
(("queueName" | "topicName") "=" channel=DslChannelIdentifier )? &
DslSubscribe :
"subscribe" "to" topic=DslChannelIdentifier ("eventBus" "=" eventBus=ID)?
DslPublish :
"publish" (("@")?eventType=[DslEvent])? "to" topic=DslChannelIdentifier ("eventBus" "=" eventBus=ID)?
DslEvent :
DslDomainEvent | DslCommandEvent;
DslDomainObjectTypedElement :
DslServiceOperation | DslRepositoryOperation | DslDomainObjectOperation | DslParameter;
DslServiceOperation :
(doc=STRING)?
(visibility=DslVisibility)?
(returnType=DslComplexType)?
name=ID ("(" (parameters+=DslParameter)?("," parameters+=DslParameter)* ")")?
("throws" throws=DslThrowsIdentifier)? &
(publish=DslPublish)?
(delegateHolder=DslServiceOperationDelegate)? ";"
DslServiceOperationDelegate :
DELEGATE ("@")? delegate=[DslServiceRepositoryOption]"."delegateOperation=[DslServiceRepositoryOperationOption];
DslServiceRepositoryOption :
DslRepository | DslService;
DslServiceRepositoryOperationOption :
DslRepositoryOperation | DslServiceOperation;
DslResourceOperation :
(doc=STRING)?
(httpMethod=DslHttpMethod)? &
("path" "=" path=STRING)? &
("return" "=" returnString=STRING)?
(delegateHolder=DslResourceOperationDelegate)? ";"
DslResourceOperationDelegate :
DELEGATE ("@")? delegate=[DslService]"."delegateOperation=[DslServiceOperation];
enum DslHttpMethod :
None | GET="GET" | POST="POST" | PUT="PUT" | DELETE="DELETE";
DslRepositoryOperation :
(doc=STRING)?
(cache?="cache")? &
((gapOperation?="gap") | (noGapOperation?="nogap"))? &
("query" "=" query=STRING)? &
("condition" "=" condition=STRING)? &
("select" "=" select=STRING)? &
("groupBy" "=" groupBy=STRING)? &
("orderBy" "=" orderBy=STRING)? &
(construct?="construct")? &
(build?="build")? &
(map?="map")? &
(delegateToAccessObject?=DELEGATE (("AccessObject") | (accessObjectName=ID)))? ";"
DslParameter :
(doc=STRING)?
parameterType=DslComplexType name=ID;
DslComplexType :
(collectionType=DslCollectionType"<"(("@"domainObjectType=[DslSimpleDomainObject]) | (type=DslType) | (type=DslType"<""@"domainObjectType=[DslSimpleDomainObject]">"))">") |
(mapCollectionType=DSL_MAP_COLLECTION_TYPE"<"(mapKeyType=DslType | "@"mapKeyDomainObjectType=[DslSimpleDomainObject])","(("@"domainObjectType=[DslSimpleDomainObject]) | (type=DslType) | (type=DslType"<""@"domainObjectType=[DslSimpleDomainObject]">"))">") |
(type=DslType) |
(type=DslType"<""@"domainObjectType=[DslSimpleDomainObject]">");
DslSimpleDomainObject :
DslBasicType | DslEnum | DslDomainObject | DslDataTransferObject | DslTrait;
DslDomainObject :
DslEntity | DslValueObject | DslEvent;
DslEntity :
(doc=STRING)?
(abstract?="abstract")? "Entity" name=ID ("extends" (("@"extends=[DslEntity]) | (extendsName=DslJavaIdentifier)))?
("with" ("@")?traits+=[DslTrait])* "{"
("package" "=" package=DslJavaIdentifier )?
(((notOptimisticLocking?=NOT "optimisticLocking") | ("optimisticLocking"))? &
((notAuditable?=NOT "auditable") | ("auditable"))? &
((cache?="cache") | (NOT "cache"))? &
("databaseTable" "=" databaseTable=STRING)? &
("discriminatorValue" "=" discriminatorValue=STRING)? &
("discriminatorColumn" "=" discriminatorColumn=STRING)? &
("discriminatorType" "=" discriminatorType=DslDiscriminatorType)? &
("discriminatorLength" "=" discriminatorLength=STRING)? &
("inheritanceType" "=" inheritanceType=DslInheritanceType)? &
("validate" "=" validate=STRING)? &
((notAggregateRoot?=NOT "aggregateRoot") | ("aggregateRoot"))? &
("belongsTo" (("@")?belongsTo=[DslDomainObject]))?)
((attributes+=DslAttribute) |
(references+=DslReference) |
(operations+=DslDomainObjectOperation))*
(repository=DslRepository)?
DslValueObject :
(doc=STRING)?
(abstract?="abstract")? "ValueObject" name=ID ("extends" (("@"extends=[DslValueObject]) | (extendsName=DslJavaIdentifier)))?
((notImmutable?=NOT "immutable") | ("immutable"))? &
((persistent?="persistent") | (notPersistent?=NOT "persistent"))? &
DslDomainEvent :
(doc=STRING)?
(abstract?="abstract")? "DomainEvent" name=ID ("extends" (("@"extends=[DslDomainEvent]) | (extendsName=DslJavaIdentifier)))?
(persistent?="persistent")? &
DslCommandEvent :
(doc=STRING)?
(abstract?="abstract")? "CommandEvent" name=ID ("extends" (("@"extends=[DslCommandEvent]) | (extendsName=DslJavaIdentifier)))?
DslTrait :
(doc=STRING)?
"Trait" name=ID "{"
DslDomainObjectOperation :
(doc=STRING)?
OP (abstract?="abstract")? (visibility=DslVisibility)?
DslDataTransferObject :
(doc=STRING)?
(abstract?="abstract")? "DataTransferObject" name=ID ("extends" (("@"extends=[DslDataTransferObject]) | (extendsName=DslJavaIdentifier)))? "{"
((attributes+=DslDtoAttribute) |
(references+=DslDtoReference))*
DslBasicType :
(doc=STRING)?
"BasicType" name=ID
(((notImmutable?=NOT "immutable") | ("immutable"))? &
DslAttribute :
(doc=STRING)?
(visibility=DslVisibility)? (collectionType=DslCollectionType"<")? type=DslType (">")? name=ID
((key?="key")? &
((notChangeable?=NOT "changeable") | ("changeable"))? &
((required?="required") | (NOT "required"))? &
(((nullable?="nullable") | (NOT "nullable")) ("=" nullableMessage=STRING)?)? &
(index?="index")? &
((assertFalse?="assertFalse") ("=" assertFalseMessage=STRING)?)? &
((assertTrue?="assertTrue") ("=" assertTrueMessage=STRING)?)? &
((creditCardNumber?="creditCardNumber") ("=" creditCardNumberMessage=STRING)?)? &
("digits" "=" digits=STRING)? &
((email?="email") ("=" emailMessage=STRING)?)? &
((future?="future") ("=" futureMessage=STRING)?)? &
((past?="past") ("=" pastMessage=STRING)?)? &
("max" "=" max=STRING)? &
("min" "=" min=STRING)? &
("decimalMax" "=" decimalMax=STRING)? &
("decimalMin" "=" decimalMin=STRING)? &
((notEmpty?="notEmpty") ("=" notEmptyMessage=STRING)?)? &
((notBlank?="notBlank") ("=" notBlankMessage=STRING)?)? &
("pattern" "=" pattern=STRING)? &
("range" "=" range=STRING)? &
("size" "=" size=STRING)? &
("length" "=" length=STRING)? &
("scriptAssert" "=" scriptAssert=STRING)? &
("url" "=" url=STRING)? &
(transient?="transient")? &
("databaseColumn" "=" databaseColumn=STRING)? &
("databaseType" "=" databaseType=STRING)?) (";")?;
DslReference :
(doc=STRING)?
REF (visibility=DslVisibility)? (collectionType=DslCollectionType"<")? (("@")?domainObjectType=[DslSimpleDomainObject]) (">")? name=ID
((key?="key")? &
("cascade" "=" cascade=STRING)? &
("fetch" "=" fetch=STRING)? &
((inverse?="inverse") | (NOT "inverse"))? &
("databaseJoinTable" "=" databaseJoinTable=STRING)? &
("databaseJoinColumn" "=" databaseJoinColumn=STRING)? &
((valid?="valid") ("=" validMessage=STRING)?)? &
("orderby" "=" orderBy=STRING)? &
((orderColumn?="orderColumn") ("=" orderColumnName=STRING)?)? &
(oppositeHolder=DslOppositeHolder)?)
DslDtoAttribute :
(doc=STRING)?
((key?="key")? &
DslDtoReference :
(doc=STRING)?
((key?="key")? &
DslOppositeHolder :
OPPOSITE opposite=[DslReference];
DslRepository :
(doc=STRING)?
"Repository" name=ID "{"
(operations+=DslRepositoryOperation)*
DslServiceDependency :
('>'|'inject') ("@"dependency=[DslService]);
DslDependency :
('>'|'inject') (("@"dependency=[DslServiceRepositoryOption])|name=ID);
DslEnum :
(doc=STRING)?
"enum" name=ID "{"
(ordinal?="ordinal")?
(attributes+=DslEnumAttribute)*
(values+=DslEnumValue) ("," values+=DslEnumValue)* (";")?
DslEnumAttribute :
(doc=STRING)?
type=DslType name=ID (key?="key")? (";")?;
DslEnumValue :
(doc=STRING)?
name=ID ("(" parameters+=DslEnumParameter ("," parameters+=DslEnumParameter)* ")")?;
DslEnumParameter :
((value=STRING) | (integerValue = INT));
DslAnyProperty :
DslProperty | DslDtoProperty;
DslProperty :
DslAttribute | DslReference;
DslDtoProperty :
DslDtoAttribute | DslDtoReference;
enum DslInheritanceType :
JOINED="JOINED" | SINGLE_TABLE="SINGLE_TABLE";
enum DslDiscriminatorType :
STRING="STRING" | CHAR="CHAR" | INTEGER="INTEGER";
DslType :
("String"|"int"|"Integer"|"long"|"Long"|"boolean"|"Boolean"|"Date"|"DateTime"|"Timestamp"|"BigDecimal"|"BigInteger"|
"double"|"Double"|"float"|"Float"|"Key"|"PagingParameter"|"PagedResult"|"Blob"|"Clob"|"Object[]"|
DslJavaIdentifier);
enum DslCollectionType :
None | Set="Set" | List="List" | Bag="Bag" | Collection="Collection";
terminal DSL_MAP_COLLECTION_TYPE :
"Map";
enum DslVisibility :
public="public" | protected="protected" | private="private" | package="package";
DslJavaIdentifier :
(ID ("." ID)*);
DslChannelIdentifier :
(ID (((".") | ("/") | (":")) ID)*);
DslThrowsIdentifier :
(DslJavaIdentifier ("," DslJavaIdentifier)*);
terminal NOT :
('!'|'not');
terminal DELEGATE :
('=>'|('delegates to'));
terminal OPPOSITE :
('<->'|'opposite');
terminal REF :
('-'|'reference');
terminal OP :
('*'|'def');
However, when I test this in Eclipse I get the following error:
I tried adding these scoping classes but it didnt make any difference.
https://github.com/sculptor/sculptor/tree/develop/sculptor-eclipse/org.sculptor.dsl/src/org/sculptor/dsl/scoping
Re: Xtext scope [message #1790066 is a reply to message #1790019] |
Mon, 04 June 2018 07:31   |
Hi Christian
Firstly, thank you for your kind help. It is greatly appreciated.
- having such a huge grammar as starting point discourages people from answering.
Yes, I can appreciate that.
I supplied the complete - and large - grammar as I thought that perhaps some readers here are already familiar with it, being that the Sculptor framework is somewhat well known.
- what do you mean by "adding scoping classes"
To clarify, I have created a new xtext project, and am using the Sculptor xtext grammar.
I then, also added the https://github.com/sculptor/sculptor/blob/develop/sculptor-eclipse/org.sculptor.dsl/src/org/sculptor/dsl/scoping/SculptordslScopeProvider.xtend to my project.
- how did you implement the namesprovider/ indexing (if you use open model element dialog in navigate menu or crtl+shift+f3 which name does it give for the DSL service)
I have not implemented any namesprivider or indexing.
I am learning Xtext, and so far I am not familiar with what a namesprovider is.
I suspect that the issue is to do with Scoping, but am not certain.
Can you please clarify - is scoping what provides the code hints when typing? Is this all it does? Or does it also provide validation?
While debugging, I can see that the methods in the ScopeProvider are called, however I am not clear on a few points. I can see that when typing in the xtext dsl ide that these methods are called.
What exactly triggers calling the ScopeProvider? Is it simply every time someone types, or is it when entering a dot?
How is the 'context' determined? A context in the ScopeProvider is an EObject? But is this determined by the current syntax, or where the cursor in the IDE?
I hope my questions make sense.
And again, thanks for any assistance.
Re: Xtext scope [message #1790074 is a reply to message #1790069] |
Mon, 04 June 2018 08:14  |
pps: the original sculptor code uses these two things
fragment = org.eclipse.xtext.generator.adapter.FragmentAdapter {
fragment = org.eclipse.xtext.generator.scoping.ImportURIScopingFragment {
generateXtendStub = true
fragment = exporting.SimpleNamesFragment2 {}
these enable the uri based import that simple names instead of qualified names beeing used.
SculptordslScopeProvider does further customization of the scoping.
FUDForum. Page generated in 0.08516 seconds
