Home » Eclipse Projects » EGit / JGit » EGit in IBM WebSphere Transformation Extender Design Studio(EGit in Design Studio)
EGit in IBM WebSphere Transformation Extender Design Studio [message #1789973] Fri, 01 June 2018 12:17 Go to next message
donthula D is currently offline donthula DFriend
How to browse GITLab URL in EGit plugin installed in IBM WebSphere Transformation Extender Design Studio.
Please help. I am new to GIT. Thank you.
Re: EGit in IBM WebSphere Transformation Extender Design Studio [message #1790193 is a reply to message #1789973] Wed, 06 June 2018 19:15 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Besides standard Git protocol EGit supports some part of the Github API and it has some support for Gerrit
but it does not (yet) have support for Gitlab specific APIs.
This means if you want to clone a repository from Gitlab you need to find its URL and then you can use EGit to interact
(clone, fetch, push etc) with your repository hosted on Gitlab.
Re: EGit in IBM WebSphere Transformation Extender Design Studio [message #1795153 is a reply to message #1789973] Mon, 17 September 2018 09:32 Go to previous messageGo to next message
liam henry is currently offline liam henryFriend
The data in the analyzed object is then passed to the JAXB code that is executed against the IBM GDM XML schema (msl.xsd) to produce an IBM Graphical data map that can be used in the IBM Integration Bus by default. However, if opened in IBM Integration Designer, the target run time of xquery can be changed to XSLT in order to be used with Datapower. (I did not test against Datapower). It is also possible to use these tools with a zOS connection.
Re: EGit in IBM WebSphere Transformation Extender Design Studio [message #1795395 is a reply to message #1795153] Fri, 21 September 2018 09:55 Go to previous messageGo to next message
Thomas Wolf is currently offline Thomas WolfFriend
Wrong forum. Ask IBM's customer support.
Re: EGit in IBM WebSphere Transformation Extender Design Studio [message #1800594 is a reply to message #1795395] Thu, 03 January 2019 07:21 Go to previous message
henry liam is currently offline henry liamFriend
The data in the analyzed object is then passed to the JAXB code that runs against the IBM GDM XML schema (msl.xsd) to produce an IBM Graphical data map that can be used in the IBM Integration Bus by default. However, if it is opened in IBM Integration Designer, the target execution time of xquery can be changed to XSLT for use with Datapower. (I did not try against Datapower). It is also possible to use these tools with a zOS connection.
Previous Topic:End of IO Stream on Bitbucket SSH Push/Pull
Next Topic:GIT Versions supported
Current Time: Sat Sep 26 00:53:51 GMT 2020
Powered by FUDForum. Page generated in 0.02461 seconds
