Home » Eclipse Projects » Eclipse Kapua » Can not connect Krua device to kapua server exception Not authorized to connect (5)(in the past device was able to connect to kapua server but recently some of my devices are not connecting to server and gives exception. )
Can not connect Krua device to kapua server exception Not authorized to connect (5) [message #1787297] Wed, 23 May 2018 09:34 Go to next message
Hemant Sangle is currently offline Hemant SangleFriend
I haven't changed the setting of CloudServiceSetting in kura not even the client-id but still I get this error below is log of kura device
2018-05-23 14:27:17,894 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - Creating a new client instance
2018-05-23 14:27:17,895 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - Using memory persistence for in-flight messages
2018-05-23 14:27:17,897 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - # ------------------------------------------------------------
2018-05-23 14:27:17,898 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  Connection Properties
2018-05-23 14:27:17,898 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  broker    = tcp://35.173.87.174:1883
2018-05-23 14:27:17,899 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  clientId  = 51284
2018-05-23 14:27:17,899 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  username  = kapua-broker
2018-05-23 14:27:17,900 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  password  = XXXXXXXXXXXXXX
2018-05-23 14:27:17,900 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  keepAlive = 30
2018-05-23 14:27:17,900 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  timeout   = 20
2018-05-23 14:27:17,901 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  cleanSession    = true
2018-05-23 14:27:17,901 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  MQTT version    = 3.1.1
2018-05-23 14:27:17,901 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  willDestination = $EDC/kapua-sys/51284/MQTT/LWT
2018-05-23 14:27:17,902 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  willMessage     =
2018-05-23 14:27:17,903 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - #  Connecting...
2018-05-23 14:27:17,903 [pool-9-thread-1] INFO  o.e.k.c.s.r.LogStatusRunnable - Notification LED fast blinking
2018-05-23 14:27:18,572 [qtp4810959-46] WARN  o.e.k.c.d.t.m.MqttDataTransport - xxxxx  Connect failed. Forcing disconnect. xxxxx {}
	at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28)
	at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:990)
	at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118)
	at java.lang.Thread.run(Thread.java:745)
2018-05-23 14:27:18,574 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - Closing client...
2018-05-23 14:27:18,578 [qtp4810959-46] INFO  o.e.k.c.d.t.m.MqttDataTransport - Closed
2018-05-23 14:27:18,579 [pool-9-thread-1] INFO  o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-05-23 14:27:18,579 [qtp4810959-46] WARN  o.e.k.w.s.GwtNetworkServiceImpl - Error connecting
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
	at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:333)
	at org.eclipse.kura.core.data.DataServiceImpl.connect(DataServiceImpl.java:493)
	at org.eclipse.kura.web.server.GwtStatusServiceImpl.connectDataService(GwtStatusServiceImpl.java:93)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
	at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at org.eclipse.kura.web.server.OsgiRemoteServiceServlet.service(OsgiRemoteServiceServlet.java:41)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1221)
	at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:153)
	at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
	at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:132)
	at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:100)
	at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:310)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:224)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1174)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1106)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
	at org.eclipse.jetty.server.Server.handle(Server.java:524)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
Caused by: Not authorized to connect (5)
	... 1 more
so can anyone guide me to solve this issue
Re: Can not connect Krua device to kapua server exception Not authorized to connect (5) [message #1808764 is a reply to message #1787297] Mon, 01 July 2019 10:10 Go to previous message
Alberto Codutti is currently offline Alberto CoduttiFriend
Hi Hemant,
It looks like that either the password or the permission are not correct.
- Alberto
Previous Topic:how to run kapua with docker-compose?
Next Topic:MySQL integration for telemetry data.
Current Time: Fri May 27 07:26:07 GMT 2022
Powered by FUDForum. Page generated in 0.02216 seconds
