Home » Modeling » TMF (Xtext) » Multiple generators
Multiple generators [message #1787296] Wed, 23 May 2018 05:33 Go to next message
Hi all,
I've created my first xtext language here: https://github.com/karypid/sbelang
It's a tiny language to describe SBE encoding and generate an XML file that conforms to SBE's schema. There is a tool for generating code from that XML file here: https://github.com/real-logic/simple-binary-encoding
My next step would be to generate Java code *in addition to* the XML file (similar to what the tool I linked above does). From the documentation, I used AbstractGenerator as my target is not Java: https://github.com/karypid/sbelang/blob/master/org.sbelang.dsl.parent/org.sbelang.dsl/src/org/sbelang/dsl/generator/SbeLangDslGenerator.xtend
Now, in order to generate Java code, I want to use the model inferrer and plug into the existing facilities as per: https://www.eclipse.org/Xtext/documentation/104_jvmdomainmodel.html
My problem is that as far as I understand, xtext decides what to do based on the statement in your grammar. Mine at https://github.com/karypid/sbelang/blob/master/org.sbelang.dsl.parent/org.sbelang.dsl/src/org/sbelang/dsl/SbeLangDsl.xtext currently has:
grammar org.sbelang.dsl.SbeLangDsl with org.eclipse.xtext.common.Terminals
Apparently to use the JVM model inferrer I need to switch to "org.eclipse.xtext.xbase.Xbase" but is it REQUIRED to only have one of the two? Ideally I want to use the same grammar/language and have 2 generators (and even be able to control programmatically whether to invoke only one of them or both). How would I go about doing that? I was hoping someone can point to some existing OSS project with that structure that I could peek into for "best practice" ?
Re: Multiple generators [message #1787298 is a reply to message #1787296] Wed, 23 May 2018 05:42 Go to previous messageGo to next message
Producing Java code with the JvmModelInferrer is only one option, and yes, it would require to use Xbase. Not sure if that is what you want. You could also write a plain code generator implementing IGenerator2.
To use multiple templates you typically write one template that injects the others and dispatch to them in their doGenerate() method. That root template has to be bound to the IGenerator2 interface in the runtime Guice module (MyDslModule).
Re: Multiple generators [message #1787320 is a reply to message #1787298] Wed, 23 May 2018 12:16 Go to previous messageGo to next message
Thank you for your pointers Karsten.
For now, I'm prototyping with two IGenerator2 implementations. My base generator looks like this:
class SbeLangDslGenerator extends AbstractGenerator {
    val xmlGenerator = new SbeLangDslXmlGenerator;
    val javaGenerator = new SbeLangDslJavaGenerator
    override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
        xmlGenerator.doGenerate(resource, fsa, context)
        javaGenerator.doGenerate(resource, fsa, context)
The SbeLangDslXmlGenerator is what SbeLangDslGenerator used to be and I am producing multiple Java files from the second. I hope I understood you correctly, but even so it seems to work.
Re: Multiple generators [message #1787331 is a reply to message #1787320] Wed, 23 May 2018 15:09 Go to previous messageGo to next message
are you sure your generator inherits from JvmModelGenerator?
this one is used for xbase based languages and uses a lot of injections so you should inject it to your SbeLangDslGenerator instead of using new
Re: Multiple generators [message #1787340 is a reply to message #1787331] Wed, 23 May 2018 16:20 Go to previous messageGo to next message
For the time being I am going with the non-JVM based via pure templates, so the grammar uses org.eclipse.xtext.common.Terminals. I am not sure what the implications of this are, but I have made progress creating Java code like this.
I feel like I understand too little to make good decisions, so I plan to do a second re-implementation using the JVM model inferrer.
Re: Multiple generators [message #1787355 is a reply to message #1787340] Thu, 24 May 2018 00:06 Go to previous messageGo to next message
Depending on your grammar (e.g. what kind of expressions you have) and your target you won't need an jvmmodelinferrer
Re: Multiple generators [message #1787524 is a reply to message #1787355] Mon, 28 May 2018 04:23 Go to previous message
You should use @Inject on the fields instead of creating them with new. You will gain more flexibility when you are consequently using dependency injection.
Previous Topic:Accessing the `IBuildContext` from the `IShouldGenerate`
Next Topic:Language A accessing B language during code generation
Current Time: Tue Jul 08 05:03:18 EDT 2025
Powered by FUDForum. Page generated in 0.05570 seconds
