Home » Eclipse Projects » Sirius » Inconsistency after deleting element based edge
Inconsistency after deleting element based edge [message #1787251] Tue, 22 May 2018 19:13 Go to next message
Tom Brandenburg is currently offline Tom BrandenburgFriend
I am currently making my first steps with Sirius and I am quite impressed.
On my way I found some strange behaviour.
1. I am starting with a clean model:
<mbse:Package xmi:version="2.0" xmlns:xmi="..." xmlns:xsi="..." xmlns:mbse="tb.mbse">
  <packagedElement xsi:type="mbse:Component"/>
</mbse:Package>
2. I am adding an element based edge between a bordered node (Port is a connection end) and a container (an invisible connection end is created in the context of the container during creation of the edge):
index.php/fa/32882/0/
3. In the model tree editor it looks like:
index.php/fa/32883/0/
4. Now I am deleting the node based edge with:
index.php/fa/32885/0/
5. It (and the connection ends) seems to be removed in the diagram and in the project explorer:
index.php/fa/32884/0/
6. But in the model editor and in the XMI file the elements are remaining:
index.php/fa/32886/0/
  <packagedElement xsi:type="mbse:Component">
    <ownedFeature xsi:type="mbse:Port" connection="//@packagedElement.3"/>
  </packagedElement>
    <ownedFeature xsi:type="mbse:ConnectionEnd" connection="//@packagedElement.3"/>
  </packagedElement>
  <packagedElement xsi:type="mbse:Connection" end="//@packagedElement.0/@ownedFeature.0 //@packagedElement.1/@ownedFeature.0"/>
</mbse:Package>
Do you have any clue on what is going on there? :)
Do I have to unset something before removing?
Thanks a lot and best regards,
Tom
Re: Inconsistency after deleting element based edge [message #1789941 is a reply to message #1787251] Fri, 01 June 2018 06:20 Go to previous messageGo to next message
Maxime Porhel is currently offline Maxime PorhelFriend
Hi Tom,
The Remove operation removes each elements from its container, then at the end of the tool operations, Sirius is supposed to remove the references from the model to the removed elements.
It seems that the model file as not been saved : did you save it ?
Do you still have the '*' in your editor tab ?
Could you check if something has been reported in the error log ?
Maxime
Maxime Porhel - Obeo
Re: Inconsistency after deleting element based edge [message #1801373 is a reply to message #1789941] Thu, 17 January 2019 19:36 Go to previous message
I looked into that project with Eclipse 4.8 again and the issue is still there.
During deleting I can see following error messages during saving:
!ENTRY org.eclipse.sirius 4 0 2019-01-17 21:41:59.991
!MESSAGE Error saving resource
!STACK 0
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object 'com.tb.mbse.impl.ConnectionImpl@17aa498e (description: null, URI: null) (name: Name, visibility: public)' is not contained in a resource.
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveImpl.java:301)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:265)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLResourceImpl.java:389)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1475)
	at org.eclipse.sirius.business.internal.session.danalysis.ResourceSaveDiagnose.hasDifferentSerialization(ResourceSaveDiagnose.java:84)
	at org.eclipse.sirius.business.internal.session.IsModifiedSavingPolicy.hasDifferentSerialization(IsModifiedSavingPolicy.java:211)
	at org.eclipse.sirius.business.internal.session.IsModifiedSavingPolicy.computeResourcesToSave(IsModifiedSavingPolicy.java:192)
	at org.eclipse.sirius.business.api.session.AbstractSavingPolicy.save(AbstractSavingPolicy.java:57)
	at org.eclipse.sirius.business.internal.session.danalysis.DAnalysisSessionImpl$1.run(DAnalysisSessionImpl.java:829)
	at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
	at org.eclipse.sirius.business.internal.session.danalysis.DAnalysisSessionImpl.doSave(DAnalysisSessionImpl.java:838)
	at org.eclipse.sirius.business.internal.session.danalysis.Saver.wrappedSave(Saver.java:142)
	at org.eclipse.sirius.business.internal.session.danalysis.Saver.access$0(Saver.java:131)
	at org.eclipse.sirius.business.internal.session.danalysis.Saver$1.run(Saver.java:119)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2289)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2311)
	at org.eclipse.sirius.business.internal.session.danalysis.Saver.saveNow(Saver.java:116)
	at org.eclipse.sirius.business.internal.session.danalysis.Saver.save(Saver.java:93)
	at org.eclipse.sirius.business.internal.session.danalysis.DAnalysisSessionImpl.save(DAnalysisSessionImpl.java:802)
	at org.eclipse.sirius.business.internal.session.danalysis.DAnalysisSessionImpl.save(DAnalysisSessionImpl.java:797)
	at org.eclipse.sirius.diagram.ui.tools.internal.resource.CustomSiriusDocumentProvider.doSaveDocument(CustomSiriusDocumentProvider.java:279)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider$1SaveOperation.execute(AbstractDocumentProvider.java:596)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider$DocumentProviderOperation.run(AbstractDocumentProvider.java:66)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider.executeOperation(AbstractDocumentProvider.java:530)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.document.AbstractDocumentProvider.saveDocument(AbstractDocumentProvider.java:579)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.performSave(DiagramDocumentEditor.java:864)
	at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.doSave(DiagramDocumentEditor.java:684)
	at org.eclipse.sirius.ui.business.internal.session.SaveSessionRunnable.run(SaveSessionRunnable.java:62)
	at org.eclipse.ui.internal.SaveableHelper$2.run(SaveableHelper.java:370)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object 'com.tb.mbse.impl.ConnectionImpl@17aa498e (description: null, URI: null) (name: Name, visibility: public)' is not contained in a resource.
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingHREF(XMLHelperImpl.java:754)
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment(XMLHelperImpl.java:725)
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHelperImpl.java:747)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefMany(XMLSaveImpl.java:2023)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1370)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1224)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XMLSaveImpl.java:2716)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1181)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSaveImpl.java:1042)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany(XMLSaveImpl.java:2417)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1553)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XMLSaveImpl.java:683)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveImpl.java:591)
	at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:251)
	... 28 more
Does somebody have an idea?
Thanks and best regards,
Tom
[Updated on: Thu, 17 January 2019 20:44]
Report message to a moderator
Previous Topic:Material for using two or more metamodels in one diagram
Next Topic:Representation diagram in Tree Description
Current Time: Sat Feb 27 19:32:07 GMT 2021
Powered by FUDForum. Page generated in 0.01953 seconds
