Home » Modeling » EMF » Use getEStructuralFeatures or getAllEStructuralFeatures?
Use getEStructuralFeatures or getAllEStructuralFeatures? [message #1787243] Tue, 22 May 2018 16:17 Go to next message
Breno Zupeli is currently offline Breno ZupeliFriend
I have to get all EStructuralFeature elements in a list.
Now I'm using it this way:
EObject model = ....
EStructuralFeature packagedElement = model.eClass().getEStructuralFeature("packagedElement");
EcoreEList list = (EcoreEList) model.eGet(packagedElement);
But I'd like to use like this:
List<EStructuralFeature> controllers = model.eClass().getEStructuralFeatures().stream().filter(x -> x instanceof PackagedElement).collect(Collectors.toList());
How can I do this?
Should I use getEStructuralFeatures or getAllEStructuralFeatures? Both return an empty list, but getEStructuralFeature("packagedElement") return an element.
Re: Use getEStructuralFeatures or getAllEStructuralFeatures? [message #1787244 is a reply to message #1787243] Tue, 22 May 2018 16:31 Go to previous messageGo to next message
You seem to be mixing metamodels. getEStructuralFeatures() is typically from Ecore, but PackagedElement is typically from UML. You therefore throw everything away with "x instanceof PackagedElement"
(If a complicated expression doesn't work, break it up into smaller parts so that you can debug it.)
Ed Willink
Re: Use getEStructuralFeatures or getAllEStructuralFeatures? [message #1787245 is a reply to message #1787244] Tue, 22 May 2018 16:43 Go to previous messageGo to next message
Ed Willink wrote on Tue, 22 May 2018 16:31
I made it, but I didn't explain my main question well.
If I use eClass().getEStructuralFeature("packagedElement") or with another string that I want, return an element. How can I get all E Structural Features?
When I use eClass().getEStructuralFeatures() or eClass().getAllEStructuralFeatures(), both return an empty list.
Re: Use getEStructuralFeatures or getAllEStructuralFeatures? [message #1787247 is a reply to message #1787245] Tue, 22 May 2018 17:35 Go to previous messageGo to next message
Sorry. I don't believe what you claim is what you actually do. If you provide a repro, it may be possible to see where your misunderstanding lies.
Ed Willink
Re: Use getEStructuralFeatures or getAllEStructuralFeatures? [message #1787256 is a reply to message #1787247] Tue, 22 May 2018 19:43 Go to previous message
Yes, I don't believe the claim either. The org.eclipse.emf.ecore.EClass.getEStructuralFeature(String) method is implemented like this in EClassImpl:
  public EStructuralFeature getEStructuralFeature(String name)
    getFeatureCount();
    if (eNameToFeatureMap == null)
      Map<String, EStructuralFeature> result = new HashMap<String, EStructuralFeature>(3 * eAllStructuralFeatures.size() / 2 + 1);
      for (EStructuralFeature eStructuralFeature : eAllStructuralFeatures)
        String key = eStructuralFeature.getName();
        EStructuralFeature duplicate = result.put(key, eStructuralFeature);
        if (duplicate != null)
          result.put(key, duplicate);
      eNameToFeatureMap = result;
    return eNameToFeatureMap.get(name);
So is implemented to create a map from the contents that are returned by getEAllStructuralFeatures(). Of course model.eClass().getEStructuralFeatures().stream().filter(x -> x instanceof PackagedElement) will definitely be an empty list because no EStructuralFeature will ever be an instance of PackageElement. Likely model.eContents().stream().filter(x -> x instanceof PackagedElement) makes more sense.
Previous Topic: [CDO] Easier Eclipse debugging on CDOObject instances
Next Topic:Obtaining the text value of a FeatureMap entry
Current Time: Sun May 31 08:21:34 GMT 2020
Powered by FUDForum. Page generated in 0.01970 seconds
