Home » Modeling » TMF (Xtext) » Validating x,y coordinates(Having issues figuring out how to validate x and y coordinates.)
Validating x,y coordinates [message #1787047] Thu, 17 May 2018 17:48 Go to next message
Jack Lee is currently offline Jack LeeFriend
Hello, I am working on an assignment and have a slight issue understanding something about validation and the grammar.
Currently this is my grammar (only showing relevant parts, ... is omitted code):
Game:
    'Game' name=ID grid=GridSize ...
GridSize:
   'Grid' 'size' size=Coordinates
Coordinates:
'('x=INT','y=INT')'
And this is my validation definition:
@Check
    def void checkGridCoordinates(Game game) {
    	val minValue = 1
    	val maxValue = 10
    	var x = game.grid.size.x
    	var y = game.grid.size.y
    	var literal = MetaGameLanguagePackage.Literals.GRID_SIZE__SIZE
    	if(x < minValue || y < minValue){
    		error("Grid size must be at least 1.",literal)
    	} else if(x > maxValue || y > maxValue) {
    		this.error("Grid size must be 10 or under.", literal)
I get the following error, which happens if I try to set the grid x and y to be either 0 or under or above 10 (which is expected but I want it to display the error message and not fail to validate):
Description	Resource	Path	Location	Type
Error executing EValidator	TestingFile.gl	/IndividualExtension/src	/IndividualExtension/src/TestingFile.gl	GameLang Problem
Since this is an assignment I would appreciate it if you could hint me in a direction in which I can experiment, instead of handing me a solution :)
Re: Validating x,y coordinates [message #1787090 is a reply to message #1787047] Fri, 18 May 2018 16:30 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
first of all you should write a unit test for your validator
the classes parsehelper and validationtesthelper will help
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
	@Inject
	ParseHelper<Game> parseHelper
	@Inject
	extension ValidationTestHelper
	@Test
	def void loadModel() {
		val result = parseHelper.parse('''
			Game HelloWorld Grid size (1,11)
		Assert.assertNotNull(result)
		val errors = result.eResource.errors
		Assert.assertTrue('''Unexpected errors: «errors.join(", ")»''', errors.isEmpty)
		result.assertNoErrors // Triggers validation
this will give you an actual stack trace (you would find it in the eclipse runtime error log too)
the stacktrace should hint you to your problem
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Validating x,y coordinates [message #1787114 is a reply to message #1787090] Sat, 19 May 2018 04:05 Go to previous messageGo to next message
Thank you very much! Turns out the issue was I was in the wrong context and thus the feature was not being exposed. However as you can see in my below code I had to use eINSTANCE and not
. I have yet to understand why Literals didn't do the job.
@Check
def void checkGridCoordinates(GridSize grid) {
    	// Variables
    	var minValue = 1
    	var maxValue = 10
    	var x = grid.size.x
    	var y = grid.size.y
    	var gridSize = MetaGameLanguagePackage.eINSTANCE.gridSize_Size
    		error("Grid size must be at least 1.", gridSize)
			error("Grid size must be 10 or under.", gridSize)
Re: Validating x,y coordinates [message #1787115 is a reply to message #1787090] Sat, 19 May 2018 04:06 Go to previous messageGo to next message
Also thank you for the unit test idea.
[Updated on: Sat, 19 May 2018 04:07]
Report message to a moderator
Re: Validating x,y coordinates [message #1787116 is a reply to message #1787115] Sat, 19 May 2018 05:14 Go to previous message
You can also have a look at the overloaded error methods that allow you to pass a explicit context
Previous Topic:How do I re-import a maven Xtext project?
Next Topic:Generated code
Current Time: Tue Oct 19 04:41:21 GMT 2021
Powered by FUDForum. Page generated in 0.01467 seconds
