Creating edges between sub nodes present in different Conatiners. [message #1787016] |
Thu, 17 May 2018 11:39 |
Rakesh Nidavani Messages: 25 Registered: March 2018 |
I have two containers and each container have a sub node each.
Note: Two containers are directly created under layer.
Sub nodes are displayed as square.
Problem(s) :
1)
When the container is created with 'free form' child representation.
When I first open the diagram , the containers will be overlapped. And the edges are not getting displayed properly. Issue persists even after clicking on arrange all.
2)
When the container is created with 'List' child representation.
The sub nodes are displayed as list (without square )
The edges are not getting created.
3)
When the container is created with 'Horizontal' or 'Vertical' stacks child representation.
The edges and sub nodes are not getting created.
Can someone please assist me in resolving this issue?
Rakesh
[Updated on: Thu, 17 May 2018 11:41] Report message to a moderator
Re: Creating edges between sub nodes present in different Conatiners. [message #1787081 is a reply to message #1787016] |
Fri, 18 May 2018 14:42 |
1) I can't reproduce your issue, do you have a custom layout that could explain it?
2) In List mode, only the sub nodes are represented only by label and you can't have an edge on a label. There is a feature request about it, but I don't think it is planned for the moment.
3) You probably miss the container mapping that defines the compatments between your container mapping in Horizontal or Vertical mode and your node mapping.
Steve
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.02753 seconds
