Home » Eclipse Projects » Sirius » Subnodes in List-Container
Subnodes in List-Container [message #1786971] Wed, 16 May 2018 16:21 Go to next message
Albrecht I is currently offline Albrecht IFriend
in my odesign i use a Container with children Presentation set to List. The labels of the children are sometimes very long. They are cut off at some zoom levels. Did i do something wrong in my VSM? Maybe a different font will work?
Best regards
Albrecht
Re: Subnodes in List-Container [message #1787012 is a reply to message #1786971] Thu, 17 May 2018 10:27 Go to previous messageGo to next message
Steve Monnier is currently offline Steve MonnierFriend
Indeed I reproduced this issue and it seems to be only at 125%. It was fine at 150% or 200%. It depends on the font used though. With some fonts there is the same issue (for instance arial) but with some other fonts it's ok (courier new). Can you file a new bugzilla about it?
Steve
Steve Monnier - Obeo
Re: Subnodes in List-Container [message #1787056 is a reply to message #1787012] Fri, 18 May 2018 04:33 Go to previous message
courier new will work for me. I also filed a bugzilla : https://bugs.eclipse.org/bugs/show_bug.cgi?id=534837
Thank you
Albrecht
Previous Topic:The feature 'activatedLayers' has a reference to '' which cannot be f
Next Topic:difference between Diagram Import and Diagram Extension
Current Time: Sat Feb 27 04:41:42 GMT 2021
Powered by FUDForum. Page generated in 0.01946 seconds
