Re: Computer Crash- Lost Eclipse Code [message #1786817 is a reply to message #1786816] |
Sun, 13 May 2018 07:23 |
Ed Merks Messages: 33139 Registered: July 2009 |
All the files, in their saved state, should still be on disk. And if you saved the file during your editing, older saved versions ought to be in the local history, in <workspace>/.metadata/.plugins/org.eclipse.core.resources/.history/*/*. If you never saved the file, of course it will have been lost. Using the context menu for the file in question (in the explorer view), you can try Compare With -> Local History... or Replace With -> Local History... to recover older saved versions. But as I said, if you never saved anything, you're kind of hosed.
There is a preference Window -> Preferences -> General Editors -> Autosave that you could enable, but that's hardly helpful at this point (and I personally would find that behavior annoying).
Ed Merks
FUDForum. Page generated in 0.08071 seconds
