Home » Eclipse Projects » Virgo » Error when launching Virgo using DCEVM patched JDK
Error when launching Virgo using DCEVM patched JDK [message #1786773] Fri, 11 May 2018 06:57 Go to next message
Rafa E is currently offline Rafa EFriend
Hi, I can't get to work Virgo using DCEVM(http://dcevm.github.io). It crashes inmediately with the following log message:
!ENTRY org.eclipse.equinox.launcher 4 0 2018-05-10 19:58:07.410
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/internal/adaptor/EclipseAdaptorMsg
	at org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorMsg.<clinit>(EclipseAdaptorMsg.java:107)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:186)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Any idea? Thanks!
Re: Error when launching Virgo using DCEVM patched JDK [message #1790518 is a reply to message #1786773] Tue, 12 June 2018 09:31 Go to previous messageGo to next message
Florian Waibel is currently offline Florian WaibelFriend
which flavour (Virgo Server for Apache Tomcat, Virgo Jetty Server, Virgo Nano, ...) and which version of Virgo are you trying to launch inside DCEVM?
florian
Re: Error when launching Virgo using DCEVM patched JDK [message #1790519 is a reply to message #1790518] Tue, 12 June 2018 09:35 Go to previous message
Hi, thanks for your response.
I managed to get it working. That error message was caused for an incorrect java version being used with DCEVM.
Thanks again.
Previous Topic:Virgo & OSGi in the new "docker" and "micro services" world?
Next Topic:Problem in loading Virgo bundles for vSphere v6.5
Current Time: Tue Jan 19 11:27:04 GMT 2021
Powered by FUDForum. Page generated in 0.02199 seconds
