Re: Eclipse EGIT plugin install Missing Requirement required items could not be found [message #1786756 is a reply to message #1786749] |
Thu, 10 May 2018 16:50 |
Jeffery DuBois Messages: 4 Registered: May 2018 |
Hi Matthias Sohn - Thank you for your prompt response!
As far as I know I do not necessarily want to install " the task focused interface / Mylyn integration" - it seems to be requiring this - is there some way to suppress that requirement?
Fyi I attempted to install egit 2.0.0.201206130900-r again, this time unselecting the "source" option and now I am receiving a different missing requirement -
EGit Import Support 2.0.0.201206130900-r (org.eclipse.egit.import.feature.group 2.0.0.201206130900-r) requires 'org.eclipse.team.core 3.6.100' but it could not be found"
Where do I find "org.eclipse.team.core 3.6.100" and/or the other missing products (e.g. 'org.kohsuke.args4j [2.0.0,3.0.0 ) .
The answer to your question regarding why we are using such an old version of eclipse (v3.6.2) is that my team is using a version of IBM's integration designer application that used eclipse 3.6.2 as its base. We are transitioning from SVN to Git and consequently we need to use the EGit plug-in that is compatible with 3.6.2.
Couple of questions:
1. A primary question - How do I determine what EGIT plug-ins are compatible with eclipse 3.6.2?
When I went to this site https://wiki.eclipse.org/EGit/FAQ#What_versions_of_Eclipse_does_EGit_target.3F I did not find v3.6.2 explicitly listed but I did find this reference:
EGit 2.0.0.201206130900-r >> Eclipse 3.5.2+ (Galileo) (except EGit Import Support feature, which is optional)
Then above where "3.5.2+" is referenced version "3.7.2+" is referenced.
3.6.2 is between the 3.5.2 and 3.7.2 ,
therefore it appears that EGit 2.0.0.201206130900-r is the correct plugin choice for my situation. Please confirm.
What I used for my attempts at installing plug-ins was EGit 2.0.0.201206130900-r and 2.3.1.201302201838-r.
I found the plugins at https://wiki.eclipse.org/EGit/FAQ#What_versions_of_Eclipse_does_EGit_target.3F
2. Apparently there may be several dependences that are missing from these plugins. How can I determine what all the missing dependencies are? Is there some way to identify these dependencies without having to execute multiple install attempts, one for each dependency failure?
Thank you for all your help! It is very much appreciated.
[Updated on: Fri, 11 May 2018 12:17] Report message to a moderator
FUDForum. Page generated in 0.07983 seconds
