Home » Modeling » TMF (Xtext) » Generated project tries to access missing URL(xtext idea download failing)
Generated project tries to access missing URL [message #1786694] Wed, 09 May 2018 14:31 Go to next message
Alex Mising name is currently offline Alex Mising nameFriend
I just created a new project and selected IDEA support. Running "gradlew build" fails with:
Execution failed for task ':org.xtext.dsl.test.idea:downloadIdeaPlugins'.
> java.io.FileNotFoundException: http://download.eclipse.org/modeling/tmf/xtext/idea/2.13.0/updatePlugins.xml
I do not actually have IntelliJ on my system so it tries to download something, but that URL is non-existent. Has this repository been moved?
Re: Generated project tries to access missing URL [message #1786695 is a reply to message #1786694] Wed, 09 May 2018 14:40 Go to previous message
Christian Dietrich is currently online Christian DietrichFriend
idea support is dead. the 2.14 wizard will no longer offer it.
you might try to build it from its sources or try to use idea with lsp instead
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:Hovers on keywors crashes
Next Topic:Setting rule values implicitly in Xtext Grammar by keyword appereance
Current Time: Fri Oct 22 11:07:24 GMT 2021
Powered by FUDForum. Page generated in 0.02152 seconds
