Home » Eclipse Projects » Eclipse 4 » RCP App freezes in Windows while showing splash-screen
RCP App freezes in Windows while showing splash-screen [message #1786486] Fri, 04 May 2018 09:38
Klaus Reger is currently offline Klaus RegerFriend
My tycho built RCP application freezes, when starting up in Windows. Under Linux everything works ok.
So I started a debugger and paused the application. It gets stopped at this place:
org.eclipse.swt.internal.win32.OS.SetWindowLongW(long, int, int) line: not available [native method]
org.eclipse.swt.internal.win32.OS.SetWindowLong(long, int, int) line: 3459
org.eclipse.swt.widgets.Shell.createHandle() line: 622
org.eclipse.swt.widgets.Shell(org.eclipse.swt.widgets.Control).createWidget() line: 758
org.eclipse.swt.widgets.Shell(org.eclipse.swt.widgets.Scrollable).createWidget() line: 151
org.eclipse.swt.widgets.Shell(org.eclipse.swt.widgets.Decorations).createWidget() line: 438
org.eclipse.swt.widgets.Shell.<init>(org.eclipse.swt.widgets.Display, org.eclipse.swt.widgets.Shell, int, long, boolean) line: 300
org.eclipse.swt.widgets.Shell.internal_new(org.eclipse.swt.widgets.Display, long) line: 423
sun.reflect.NativeMethodAccessorImpl.invoke0(java.lang.reflect.Method, java.lang.Object, java.lang.Object[]) line: not available [native method]
sun.reflect.NativeMethodAccessorImpl.invoke(java.lang.Object, java.lang.Object[]) line: not available
sun.reflect.DelegatingMethodAccessorImpl.invoke(java.lang.Object, java.lang.Object[]) line: not available
java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object...) line: not available
org.eclipse.ui.internal.WorkbenchPlugin.getSplashShell(org.eclipse.swt.widgets.Display) line: 1257
org.eclipse.ui.internal.Workbench$6.run() line: 839
org.eclipse.core.runtime.SafeRunner.run(org.eclipse.core.runtime.ISafeRunnable) line: 42
org.eclipse.ui.internal.Workbench.createSplashWrapper() line: 894
org.eclipse.ui.internal.Workbench.access$6(org.eclipse.ui.internal.Workbench) line: 816
org.eclipse.ui.internal.Workbench$5.run() line: 662
org.eclipse.core.databinding.observable.Realm.runWithDefault(org.eclipse.core.databinding.observable.Realm, java.lang.Runnable) line: 336
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(org.eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 610
org.eclipse.ui.PlatformUI.createAndRunWorkbench(org.eclipse.swt.widgets.Display, org.eclipse.ui.application.WorkbenchAdvisor) line: 148
de.patronas.tradedirector.client.rcp.core.app.Application.lockAndRunWorkbench(org.eclipse.swt.widgets.Display) line: 98
de.patronas.tradedirector.client.rcp.core.app.Application.start(org.eclipse.equinox.app.IApplicationContext) line: 59
org.eclipse.equinox.internal.app.EclipseAppHandle.run(java.lang.Object) line: 196
org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run() line: 26
java.lang.Thread.run() line: not available
Any ideas, how to fix this problems?
Thanks in advance, Klaus
[Updated on: Fri, 04 May 2018 09:41]
Report message to a moderator
Previous Topic:How to programmatically add menus to the main menu bar?
Next Topic:target platform error in mac
Current Time: Sat Jan 25 20:00:29 GMT 2020
Powered by FUDForum. Page generated in 0.02052 seconds
