A performance confuse of thumbnail [message #1786218] |
Fri, 27 April 2018 05:21 |
mind calm Messages: 57 Registered: July 2017 |
Member |
I found that, when i editing model with sirius diagram, if i open outline overview, the editing performance will be worse. I analysed the source code, found the ToggleUpdateManager.performUpdate() is responded for painting the sirius diagram; the ThumbnailUpdater.run() is responded for updating the outline overview. Is my analysis correct or not?
My confuse is that, why the ThumbnailUpdater.run() costs more time than the ToggleUpdateManager.performUpdate()? Did not the ThumbnailUpdater.run() just scale down the picture which ToggleUpdateManager.performUpdate() painted?
Best regards!
by Keep Mind Calm
Re: A performance confuse of thumbnail [message #1786222 is a reply to message #1786218] |
Fri, 27 April 2018 07:21 |
The outline view is provided by default by GEF. Indeed, we noticed this performance issue but since GEF 3 is not maintained anymore, this issue will probably not be addressed.
The only workaround is to close this view for diagrams with a huge amount of figure :-(
Florian
Re: A performance confuse of thumbnail [message #1786478 is a reply to message #1786222] |
Fri, 04 May 2018 05:53 |
Member |
Hi, Florian Barbin
Thanks for your reply.
I debugged the process, It seams that, the thumbnail paint all the figures recursively, while the ToggleUpdateManager.performUpdate() only paint part of the figures, according to a HashMap named dirtyRegions which stores the affected picture and its dirty region.
Best regards!
by Keep Mind Calm
FUDForum. Page generated in 0.03239 seconds
