Eclipse Won't Open Suddenly (Resolved) [message #1786057] |
Wed, 25 April 2018 03:52  |
Arthur White Messages: 4 Registered: April 2018 |
Dear kind , gentle, generous, helpful reader,
So I was happily working with an older version of Eclipse (4.4.1) rand easily migrated to 4.7.3 (with JDK 10) and I have a ton of projects that I was using with 4.7.3. Then I installed Intellij Idea 2018.1.1 and I did not even get to creating a single project in IntelliJ when I tried to open my old workspace to migrate some files to intellij (I wanted to use their UML class diagram synchronization design feature among others like analytics and software metrics tools etc.).
When I tried to open my eclipse projects to see my java source files it gave me an error :
An error has occurred see the log file C:\workspace\.metadata\.log
I open the .log file and this is the error I see there (also attached entire log file - though the main error is pasted here )
!SESSION 2018-04-24 23:10:54.245 -----------------------------------------------
eclipse.buildId=4.7.3.M20180330-0640
java.version=10.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2018-04-24 23:11:03.058
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
I looked at the bug report here :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=493761
and I noticed that the eclipse.ini file does have add-modules=ALL-SYSTEM
set (you can check the attached eclipse.ini).
So any help would be appreciated.
BTW my environment variables just has PATH set pointing to jdk 10 (attaching screenshot of the path variable).
Any help would be appreciated.
Sincerely and respectfully, a happy Tuesday to all!
Attachment: log
(Size: 726.60KB, Downloaded 96 times)
Attachment: eclipse.ini
(Size: 0.57KB, Downloaded 111 times)
Attachment: PathVar.PNG
(Size: 20.56KB, Downloaded 115 times)
[Updated on: Wed, 25 April 2018 16:12] Report message to a moderator
Re: Eclipse Won't Open Suddenly [message #1786072 is a reply to message #1786062] |
Wed, 25 April 2018 07:36   |
It's not the only duplicate. Can you do some more clean up and post the new ini file, and a fresh log file (backup and delete the one that's there) if it continues to fail?
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03135 seconds
