Home » Newcomers » Newcomers » Tomcat times out while attempting to start(Tomcat not starting)
Tomcat times out while attempting to start [message #1785913] Mon, 23 April 2018 05:55 Go to next message
David Seever is currently offline David SeeverFriend
I lengthened the timeout to 2 minutes and still received the timeout error message. Also removed and re-installed Eclipse. I couldn't find an answer through a regular web search.
Tomcat will start from a command prompt.
My last hope are the experts. Any suggestions?
CONFIGURATION:
WIndows 10, Tomcat 9, Eclipse Java EE IDE for Web Developers.
Version: Oxygen.3a Release (4.7.3a)
Build id: 20180405-1200
ports 8080, 8080, 8009
ERROR MESSAGE:
Starting tomcat at localhost has encountered a problem. server tomcat at localhost was unable to start within 45 seconds.
CONSOLE OUTPUT:
Apr 22, 2018 9:59:52 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:Lesson41' did not find a matching property.
Apr 22, 2018 9:59:52 PM org.apache.catalina.startup.VersionLoggerListener log
INFO: Server version: Apache Tomcat/9.0.7
INFO: Server built: Apr 3 2018 19:53:05 UTC
INFO: Server number: 9.0.7.0
INFO: OS Name: Windows 10
INFO: OS Version: 10.0
INFO: Architecture: amd64
INFO: Java Home: D:\Java\jre
INFO: JVM Version: 1.8.0_131-b11
INFO: JVM Vendor: Oracle Corporation
INFO: CATALINA_BASE: E:\temp\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: CATALINA_HOME: E:\myWebProject\tomcat
INFO: Command line argument: -Dcatalina.base=E:\temp\.metadata\.plugins\org.eclipse.wst.server.core\tmp0
INFO: Command line argument: -Dcatalina.home=E:\myWebProject\tomcat
INFO: Command line argument: -Dwtp.deploy=E:\temp\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps
INFO: Command line argument: -Djava.endorsed.dirs=E:\myWebProject\tomcat\endorsed
INFO: Command line argument: -Dfile.encoding=UTF-8
Apr 22, 2018 9:59:52 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: [D:\Java\jre\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;D:/Java/jre/bin/server;D:/Java/jre/bin;D:/Java/jre/lib/amd64;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;D:\Java\jdk1.8.0_131\bin;D:\Users\Dave\Git\cmd;C:\Users\Dave\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\Dave\AppData\Local\Programs\Python\Python37\;C:\Users\Dave\AppData\Local\Microsoft\WindowsApps;;E:\eclipse\eclipse;;.]
Apr 22, 2018 9:59:52 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-nio-8080"]
Apr 22, 2018 9:59:52 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
INFO: Using a shared selector for servlet write/read
INFO: Initializing ProtocolHandler ["ajp-nio-8009"]
Apr 22, 2018 9:59:52 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1694 ms
Apr 22, 2018 9:59:52 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service [Catalina]
Apr 22, 2018 9:59:52 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/9.0.7
Re: Tomcat times out while attempting to start [message #1786135 is a reply to message #1785913] Thu, 26 April 2018 00:21 Go to previous message
I fixed the problem by removing Tomcat and Eclipse. I re-installed both (using the Eclipse installer for the JEE IDE) and left all the default settings as-is. Now it works.
Previous Topic:sqLite-stored data can be shown in JTextField but not JTextArea
Next Topic:Checkstyle execution failed due to an internal error. Please check the error log for details
Current Time: Wed Feb 19 22:56:45 GMT 2020
Powered by FUDForum. Page generated in 0.03065 seconds
