Home » Eclipse Projects » Oomph » Central setup file, workspace settings
Central setup file, workspace settings [message #1785716] Wed, 18 April 2018 17:28 Go to next message
David Coley is currently offline David ColeyFriend
Member
I feel I am missing something obvious:
- Centralized eclipse catalog with settings for Eclipse Neon (example).
- Sets which plug-ins to install from what p2 locations
- Sets up Instance wide configurations using ${installation.location|uri}
What I don't know is how to do a Resource Creation for plug-ins that are required on the Workspace level for preferences
How do I include these settings in a central repository?
Re: Central setup file, workspace settings [message #1785718 is a reply to message #1785716] Wed, 18 April 2018 17:52 Go to previous messageGo to next message
Member
Missed the obvious:
${workspace.location|uri}
Re: Central setup file, workspace settings [message #1785729 is a reply to message #1785718] Thu, 19 April 2018 05:27 Go to previous message
Also note the comments in this thread:
https://www.eclipse.org/forums/index.php/m/1751893/?srch=workspace.location+osgi#msg_1751893
I.e., workspace.location only works when/because there is a Workspace task whereas ${osgi.instance.area} always works, but note that in the installer this denotes the instance area of the installer itself, so if you use this in a task, it should not be a task that's performed at bootstrap time.
Previous Topic:Issue with installer (64bit photon)
Next Topic:How prevent Eclipse from overwriting its settings with the Oomph user.setup settings?
Current Time: Thu Apr 02 23:30:14 GMT 2020
Powered by FUDForum. Page generated in 0.02794 seconds
