Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Composite Function Block(Unsupported Type)
Composite Function Block [message #1785596] Tue, 17 April 2018 10:51 Go to next message
Anugerah Nuri Satria is currently offline Anugerah Nuri SatriaFriend
Member
I tried to make composite function block from the example in 4diac. After i download it to forte pc, the deployment console shows one error telling it has "unsupported type". What step i have missed ?
Re: Composite Function Block [message #1785597 is a reply to message #1785596] Tue, 17 April 2018 10:55 Go to previous messageGo to next message
Jose Maria Jesus Cabral Lassalle is currently offline Jose Maria Jesus Cabral LassalleFriend
When you create a new type of function block you have two possibilities to make it run on the runtime environment (forte): 1- You can export the type as forte C++ code and then recompile forte including the FB (https://www.eclipse.org/4diac/documentation/html/installation/install.html#ownFORTE)
2- You can compile forte with the lua feature and then deploy it to forte. The documentation of this process is still not ready
Re: Composite Function Block [message #1785600 is a reply to message #1785597] Tue, 17 April 2018 11:29 Go to previous message
Martin Melik-Merkumians is currently offline Martin Melik-MerkumiansFriend
Member
I would recommend to compile it, as the LUA feature still has some major bugs
Previous Topic:Is IEC 61499 is suitable for discrete manufacturing?
Next Topic:FB_RANDOM_0 inputs - 4DIAC1.8.4 Ubuntu
Current Time: Tue Oct 27 17:25:55 GMT 2020
Powered by FUDForum. Page generated in 0.02369 seconds
