Home » Newcomers » Newcomers » Slow Eclipse(Slow eclipse on an Intel Core i5 8GB RAM, SSD memory)
Slow Eclipse [message #1785569] Mon, 16 April 2018 22:29
Raul Suarez is currently offline Raul SuarezFriend
Hello a few months ago I started using eclipse.
First, I used eclipse on an Intel Core Celeron 4GB of RAM with hard drive, and I had never noticed delay when writing code or when running programs. Adding that the PC had Windows 7, it was 32 bits, therefore, I installed the 32-bit version of Eclipse.
The problem is that a couple of weeks ago I bought an Intel Core i5 with 8GB of RAM and SSD memory, and eclipse often slows down while writing the code and also takes time to execute the programs. In this case it is a 64-bit PC, and I use Windows 10.
I use this forum to check if someone else has happened, and if there is a solution to correct these problems.
Excuse me for my English, greetings and thanks
Previous Topic:Installing of eclipse is crashing (WIN10)
Next Topic:Build error-'strdup' was not declared in this scope
Current Time: Fri Jun 05 17:21:52 GMT 2020
Powered by FUDForum. Page generated in 0.03389 seconds
