I can't install eclipse [message #1785473] |
Sat, 14 April 2018 16:55  |
Sorry if I am not the first one to have this problem but I can't install eclipse IDE.
When I try to install it, it says "Installation failed with an error. Show log." And in the log it says:
[2018-04-14 18:45:30] Executing bootstrap tasks
[2018-04-14 18:45:30] Java(TM) SE Runtime Environment 1.8.0_161-b12
[2018-04-14 18:45:30] Product org.eclipse.products.epp.package.java.oxygen
[2018-04-14 18:45:30] Bundle org.eclipse.oomph.setup 1.9.0.v20171202-1121, build=3282, branch=f99b41819cc9f86beec6b54bf453173fc2d4acef
[2018-04-14 18:45:30] Bundle org.eclipse.oomph.setup.core 1.9.0.v20171202-1121, build=3282, branch=f99b41819cc9f86beec6b54bf453173fc2d4acef
[2018-04-14 18:45:30] Bundle org.eclipse.oomph.setup.p2 1.9.0.v20171202-1121, build=3282, branch=f99b41819cc9f86beec6b54bf453173fc2d4acef
[2018-04-14 18:45:30] Performing P2 Director (Eclipse IDE for Java Developers (Oxygen))
[2018-04-14 18:45:30] Offline = false
[2018-04-14 18:45:30] Mirrors = true
[2018-04-14 18:45:30] Resolving 25 requirements from 3 repositories to /Users/michel/Desktop/java-oxygen/Eclipse.app/Contents/Eclipse
[2018-04-14 18:45:30] Requirement epp.package.java [4.7.0,4.8.0)
[2018-04-14 18:45:30] Requirement org.eclipse.platform.feature.group [4.7.0,4.8.0)
[2018-04-14 18:45:30] Requirement org.eclipse.rcp.feature.group [4.7.0,4.8.0)
[2018-04-14 18:45:30] Requirement org.eclipse.buildship.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.eclemma.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.egit.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.egit.mylyn.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.jdt.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.jgit.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.m2e.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.m2e.logback.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.context_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.git.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.hudson.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.java_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.mylyn_feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.recommenders.mylyn.rcp.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.recommenders.news.rcp.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.recommenders.rcp.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.recommenders.snipmatch.rcp.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2018-04-14 18:45:30] Requirement org.eclipse.oomph.setup.feature.group
[2018-04-14 18:45:30] Repository http://download.eclipse.org/technology/epp/packages/oxygen
[2018-04-14 18:45:30] Repository http://download.eclipse.org/releases/oxygen
[2018-04-14 18:45:30] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2018-04-14 18:45:31] ERROR: org.eclipse.equinox.p2.metadata.repository code=1002 Unable to read repository at http://download.eclipse.org/technology/epp/packages/oxygen.
org.tukaani.xz.XZFormatException: Input is not in the XZ format
at org.tukaani.xz.common.DecoderUtil.decodeStreamHeader(Unknown Source)
at org.tukaani.xz.SingleXZInputStream.initialize(Unknown Source)
at org.tukaani.xz.SingleXZInputStream.<init>(Unknown Source)
at org.tukaani.xz.XZInputStream.<init>(Unknown Source)
at org.eclipse.equinox.internal.p2.metadata.repository.XZedSimpleMetadataRepositoryFactory.load(XZedSimpleMetadataRepositoryFactory.java:80)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:409)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:201)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:476)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
can anyone help me with that?
Re: I can't install eclipse [message #1785496 is a reply to message #1785493] |
Sun, 15 April 2018 16:25   |
Does it consistently produce this same result from repeated attempts? Unfortunately the download.eclipse.org server will "transparently" redirect requests to a mirror closer to you, and if that mirror has a bad copy of the repository metadata, that could produce a result like this. I say "unfortunately" because there is no way to turn the behavior off nor otherwise control it, nor is it clear which mirror is being used, so its hard to tell which mirror might have a bad copy so that it can be removed from the server's list.
Re: I can't install eclipse [message #1786691 is a reply to message #1785496] |
Wed, 09 May 2018 13:45   |
Ed Merks wrote on Sun, 15 April 2018 12:25Does it consistently produce this same result from repeated attempts? Unfortunately the download.eclipse.org server will "transparently" redirect requests to a mirror closer to you, and if that mirror has a bad copy of the repository metadata, that could produce a result like this. I say "unfortunately" because there is no way to turn the behavior off nor otherwise control it, nor is it clear which mirror is being used, so its hard to tell which mirror might have a bad copy so that it can be removed from the server's list.
Which .xz file is it looking for specifically? We can include those in our mirror checks specifically.
Re: I can't install eclipse [message #1786703 is a reply to message #1786697] |
Wed, 09 May 2018 15:49   |
Dennis, here is a specific bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=534434
Similar problem reports pop up for different repos on various occasions, none of them ever reproducible. So one possible theory is a corrupted mirror that's been transparently used for the repository metadata itself. But that's impossible to confirm because this is not tracked internally in p2 the way the explicit use of mirrors is tracked when downloading the artifacts themselves.
FUDForum. Page generated in 0.09386 seconds
