Re: Problem with 4DIAC 1.9.0 versions on Mac OS X [message #1785642 is a reply to message #1785384] |
Tue, 17 April 2018 18:27 |
hi,
I have a Mac with the same setup as you. I've tried RC2 some weeks ago and today I installed RC3 today and it worked as I would have expected.
When you start 4diac do you get till the workspace chooser dialog? If yes could you try a workspace in your users working directory. Maybe you don't have write access at that location.
However I most confess I only have a mac for doing some small 4diac tests, so I don't know much about this system.
Re: Problem with 4DIAC 1.9.0 versions on Mac OS X [message #1785849 is a reply to message #1785811] |
Fri, 20 April 2018 15:30 |
hi,
hmh i think this is beyond my knowledge of the MAC. I can describe how I installed and maybe I did something different then you. So I downloaded the dmg package, and when finished double clicked on it. Then this funny "install window" appears and I draged the 4diac into apps. I think at this point and when later starting 4diac from the launcher i got the warning that this is internet content if I really want to start and then the workspace chooser appeared and then I could start. Does this help?
FUDForum. Page generated in 0.03747 seconds
