Home » Modeling » M2T (model-to-text transformation) » guery name
guery name [message #1785303] Thu, 12 April 2018 09:40 Go to next message
khouloud AYARI is currently offline khouloud AYARIFriend
Member
hey,
I want to create a query that reads names from my UML model, I've tried to look for it in the internet but nothing helpful!
Does any one know the how can I do it?
thank u ^^
[Updated on: Thu, 12 April 2018 09:49]
Report message to a moderator
Re: guery name [message #1785304 is a reply to message #1785303] Thu, 12 April 2018 09:47 Go to previous messageGo to next message
I strongly recommend that you follow the Acceleo tutorials, read the documentation and examine the examples before asking more newbie questions that are far too vague to answer, but which appear to have trivial solutions.
Ed Willink
Re: guery name [message #1785305 is a reply to message #1785304] Thu, 12 April 2018 09:50 Go to previous messageGo to next message
Member
hey,
will do ^^''
regards
Re: guery name [message #1785316 is a reply to message #1785305] Thu, 12 April 2018 10:58 Go to previous messageGo to next message
Member
Hey,
So I've been reading about query
and this is what I managed to do :
[template public generate(m : Model)]
[comment @main/]
[file (m.name, false, 'UTF-8')]
import QtQuick 2.2
[for (b:uml::Class|m.eAllContents(Class))]
[if(self.eContents()->select(b | b.getName = 'Item'))]
[GenerateClass(b)/]
[/if]
[/for]
[/file]
[/template]
[query public getName (c:Class) :Set(Property) =
c.attribute->select(visibility = VisibilityKind::public)
but I got that error :
Unrecongnized variable "getName"
I dont knw why it's not recognizing it :/ !
Re: guery name [message #1785343 is a reply to message #1785316] Thu, 12 April 2018 19:07 Go to previous messageGo to next message
louis andia. is currently offline louis andia.Friend
Member
You have to access your attributes directly: b.name (like you did with m.name, isn't it?)
Re: guery name [message #1785375 is a reply to message #1785343] Fri, 13 April 2018 07:59 Go to previous message
I suspect that "Unrecongnized variable "getName"" is the answer. getName is not a variable. Since you declared an Operation query, perhaps you meant "getName()"; operations are invoked with parentheses; just like Java and C and ....
Ed Willink
Previous Topic:How to get the location of the currently executing template in java wrapper
Next Topic:Save the text file generated in other project
Current Time: Wed Feb 19 18:53:10 GMT 2020
Powered by FUDForum. Page generated in 0.01562 seconds
