TTCN3_Compiler problem [message #1785229] |
Wed, 11 April 2018 08:56 |
Mengxuan Zhao Messages: 1 Registered: April 2018 |
We have an issue with the ttcn3_compiler command line.
The test aims to send a small message to a simple UDP or TCP server and checks the returned message.
The issue is at the point of sending the message. It seems that the tester's port and the SUT's port is not at all mapped.
The following is the module that declares the UDP port and TCP port
module Types {
type enumerated ECommandType {
E_COMMAND_HELLO(0),
E_COMMAND_ECHO(1),
E_COMMAND_REVERSE(2),
E_COMMAND_COUNT(3),
E_COMMAND_NONE(4)
type record Message {
ECommandType msgType,
charstring msgContent optional
type port UDPPort message {
out Message;
in charstring;
type port TCPPort message {
out Message;
in charstring;
type component Tester {
port UDPPort pUDPPort;
port TCPPort pTCPPort;
timer t := 5.0;
The compilation command we used is We checked the generated .cc and .hh files by ttcn3_compiler. For both TCPport and UDPport, there is one .cc and one .hh generated. They are almost empty. That's why the correct message out and remote IP address are not assigned to the tester, so the test gets timeout.
That is more curious, is that we successfully compiled the test once several months ago with the same ttcn code. The compiled .cc and .hh files are completely different.
You can find the problematic .cc and .hh files in the attached file (UDPPort.cc; UDPPort.hh), as well as the successful compiled files (UDPPort.suc.cc; UPDPort.suc.hh).
Does anyone have an idea what could be the problem?
Many thanks,
Mengxuan
Attachment: UDPPort.hh
(Size: 1.09KB, Downloaded 79 times) -
Attachment: UDPPort.cc
(Size: 1.19KB, Downloaded 79 times) -
Attachment: UDPPort.suc.cc
(Size: 3.75KB, Downloaded 86 times) -
Attachment: UDPPort.suc.hh
(Size: 1.49KB, Downloaded 73 times)
Re: TTCN3_Compiler problem [message #1785327 is a reply to message #1785229] |
Thu, 12 April 2018 14:14 |
Hi Mengxuan,
I think there's a misunderstanding here regarding the generation of test ports:
Titan can only generate a more or less empty frame, called skeleton, which then has to be added substance manually; these skeletons are not fully functional test ports.
Generating test port skeletons (and not test ports) is being done with the compiler option -t:
-t: generate Test Port skeleton
Obviously adding own code has been done with your UDPPort.suc.cc , UDPPort.suc.hh pair, but not with the other pair, which is the one directly generated by Titan.
So you should find out where you have the modified test port from and use that one if that matches your intentions; else, you have to add your own code to the generated skeletons (see Titan's documentation for details).
For clarity please check the test ports published in source in
https://github.com/eclipse/titan.core
(see links towards the bottom of the page). If you wish you can generate the skeletons
from the TTCN-3 code and compare them with the code of the fully functional test ports to see the difference.
Best regards
Elemer
FUDForum. Page generated in 0.02304 seconds
