Home » Newcomers » Newcomers » Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati(Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor.)
Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati [message #1785212] Wed, 11 April 2018 05:09 Go to next message
Gaurav Gupta is currently offline Gaurav GuptaFriend
Please help fixing this issue. I just had windows 10 updated yesterday and today i am seeing this error.
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:291)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:286)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3098)
at org.eclipse.ui.internal.ReopenEditorMenu.open(ReopenEditorMenu.java:277)
at org.eclipse.ui.internal.ReopenEditorMenu.access$1(ReopenEditorMenu.java:261)
at org.eclipse.ui.internal.ReopenEditorMenu$1$1.widgetSelected(ReopenEditorMenu.java:235)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (216).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.eclipse.egit.ui.Activator.hasJavaPlugin(Activator.java:753)
at org.eclipse.egit.ui.Activator.registerTemplateVariableResolvers(Activator.java:320)
at org.eclipse.egit.ui.Activator.start(Activator.java:312)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:177)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:108)
at org.eclipse.ui.internal.Workbench$47.runWithException(Workbench.java:2447)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2442)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1678)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2944)
at org.eclipse.ui.internal.Workbench.access$9(Workbench.java:2875)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:684)
... 16 more
Caused by: org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
... 67 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jdt/core/WorkingCopyOwner
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
... 70 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.core (206).
... 79 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
... 88 more
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
at org.eclipse.core.internal.events.ResourceChangeListenerList.remove(ResourceChangeListenerList.java:146)
at org.eclipse.core.internal.events.NotificationManager.removeListener(NotificationManager.java:313)
at org.eclipse.core.internal.resources.Workspace.removeResourceChangeListener(Workspace.java:2206)
at org.eclipse.jdt.internal.core.ExternalAnnotationTracker.shutdown(ExternalAnnotationTracker.java:132)
at org.eclipse.jdt.internal.core.JavaModelManager.shutdown(JavaModelManager.java:5211)
at org.eclipse.jdt.internal.core.JavaModelManager.startup(JavaModelManager.java:5187)
at org.eclipse.jdt.core.JavaCore.start(JavaCore.java:5833)
... 95 more
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1828696 is a reply to message #1785212] Tue, 16 June 2020 18:26 Go to previous messageGo to next message
Anshul  Das is currently offline Anshul DasFriend
I am also getting the same error while using the git button from Z/OS developer
Preferences>Team>Git>Configuration
Unable to create the selected preference page.
An error occurred while automatically activating bundle org.eclipse.egit.ui (5324).
I read many posts related to this topic & they are suggesting to delete a version of SLF4j. Though my eclipse shows 2 versions of it but I am not able to locate find the location on windows10to delete it. Please assist. I have attached the slf4j files versions.
  • Attachment: giterror.JPG
    (Size: 60.35KB, Downloaded 23 times)
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1828717 is a reply to message #1785212] Wed, 17 June 2020 13:53 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
There have been a number of updates to Java 8 since the version (111) in your log. Try updating to a newer Java 8. Also, it looks like your Eclipse version went backwards somehow between sessions--if updating your copy of Java does not help, there's a new release out today that I'd suggest for reinstalling instead.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compi [message #1828722 is a reply to message #1828717] Wed, 17 June 2020 15:43 Go to previous message
Thank you Nitin. I will try that & see if any of those 2 options work for me.
Previous Topic:Issues with Plugin Projects after installing Kura
Next Topic:Java FX: Changes in FXML not being recognized in Run
Current Time: Thu Sep 24 15:37:46 GMT 2020
Powered by FUDForum. Page generated in 0.03611 seconds
