Home » Newcomers » Newcomers » run time path problem(run time path properties)
run time path problem [message #1785132] Mon, 09 April 2018 21:12 Go to next message
sydney faria is currently offline sydney fariaFriend
Member
I created a project and then deleted it from the disk, saving the .c and .h files needed for the project. I then recreated the same project from the original folder that I imported into the new project which is named the same as the originally deleted project. Then I did a build and all worked out as expected: the .exe file is in the binaries directory, and the .o and .exe files are in the debug directory. So I should be able to run this project, but when I try to do so I get "A program file was not specified in the launch configuration." error message and no run time of the .exe files happens. There must be a problem with the project properties setup, but I cannot find out what that is.
Re: run time path problem [message #1785158 is a reply to message #1785132] Tue, 10 April 2018 07:26 Go to previous message
It's probably better to ask on the CDT forum: https://www.eclipse.org/forums/eclipse.tools.cdt
Previous Topic:mqtt test broker
Next Topic:Installing java runtime from eclipse package
Current Time: Tue Feb 18 16:37:22 GMT 2020
Powered by FUDForum. Page generated in 0.04723 seconds
