Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Palette misses components - 4DIAC 1.9.0 RC3
Palette misses components - 4DIAC 1.9.0 RC3 [message #1784727] Tue, 03 April 2018 09:40 Go to next message
agostino a is currently offline agostino aFriend
I have the last version of 4DIAC, 1.9.0 RC3 for Ubuntu.
Can you tell me why I cannot see in the Palette window "FBRT" and "hmi" (I need IN_EVENT_FB for the tutorial number 2)? How to get it?
I have:
index.php/fa/32517/0/
Thanks!
Re: Palette misses components - 4DIAC 1.9.0 RC3 [message #1784752 is a reply to message #1784727] Tue, 03 April 2018 14:40 Go to previous messageGo to next message
Alois Zoitl is currently offline Alois ZoitlFriend
As I already pointed out in this post [1] that with the migration to an Eclipse project it is harder to distribute 3rd party content with 4diac. Therefore, in order to not further delay (as we are anyhow late) the next release we will not distribute fbrt with 4diac 1.9.0. however you can get FBRT and the FBRT function blocks from www.holobloc.com or from older 4diac versions.
[1] https://www.eclipse.org/forums/index.php/t/1092434/
Re: Palette misses components - 4DIAC 1.9.0 RC3 [message #1784781 is a reply to message #1784752] Wed, 04 April 2018 07:31 Go to previous messageGo to next message
Thanks! I have dowloaded version 1.9.0RC3 and just copy-pasted the "template" folder, merging contents.
P.S.: I have been using version 1.8.4 because I could not find the components that I needed during the tutorials, and I expected the tutorials to be straighforward :)
Re: Palette misses components - 4DIAC 1.9.0 RC3 [message #1784854 is a reply to message #1784781] Wed, 04 April 2018 20:32 Go to previous message
I totaly agree that the tutorials should be straight forward. Unfortunately we where so far not able to update everything. But I strongly hope that in the near future we are able to update the typlib to a 1.8,.x state.
Previous Topic:Issue with IEC 61131-3 FIND (string conversion) function block
Next Topic:[SOLVED] X+3 example on 4DIAC 1.9.0 RC3
Current Time: Sat Apr 04 22:14:09 GMT 2020
Powered by FUDForum. Page generated in 0.01591 seconds
