Archlinux, Eclipse Oxygen, Papyrus, palette and diagram issue [message #1784493] |
Wed, 28 March 2018 16:15 |
Michele Mastrosimone Messages: 1 Registered: March 2018 |
Hello everybody,
I am completely new to Papyrus and this forum.
Here I am trying to learn how to define profiles and stereotypes using this guide.
The problem is that it seems I cannot drop elements (except for "Import Metaclass") from the palette to the diagram, altough the palette is visible and the elements selectable. The pointer looks as if I can drop the element in the diagram, but when I click on the diagram nothing appears.
If I create an element from the ".uml" file and save, then the element appears. Actually, not every element appear in this fashion: for example it seems that even certain metaclass elements does not appear on the diagram even if they are listed in the .uml file.
What can I do to solve this issue?
Thank you,
Michele
FUDForum. Page generated in 0.03116 seconds
