Re: Single-Click Rebuild Project [message #1784426 is a reply to message #1784420] |
Tue, 27 March 2018 19:32 |
If you have Build Automatically turned off, then a Build Clean should have an option at the bottom to prostrate a build immediately. Otherwise a Build Clean should trigger an automatic build.
Could you describe your situation and what you're trying to do, or why you're having to do what you're doing?
Brian.
Re: Single-Click Rebuild Project [message #1784431 is a reply to message #1784429] |
Tue, 27 March 2018 20:41 |
Note that with Project > Build Automatically enabled, doing a Project > Clean... / Build Clean will automatically trigger a full rebuild. You will see a Building workspace job if you open the Progress view (Window > Show View > Other > Progress).
FUDForum. Page generated in 0.03643 seconds
