Home » Newcomers » Newcomers » Easiest way to build Eclipse IDE (JAVA) on my local PC
Easiest way to build Eclipse IDE (JAVA) on my local PC [message #1784206] Fri, 23 March 2018 14:01 Go to next message
Ioannis Bat is currently offline Ioannis BatFriend
I had a difficulty in finding an easy way to build "Eclipse IDE for JAVA programming" on my local PC.
First of all, which source code should I use?
Furthermore, it would be great if anyone could provide me with easy steps to do so.
Thanks in advance
[Updated on: Sat, 24 March 2018 02:05]
Report message to a moderator
Re: Easiest way to built Eclipse IDE (JAVA) on my local PC [message #1784227 is a reply to message #1784206] Fri, 23 March 2018 18:02 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
The EPP project produces the downloadable packages, such as "IDE for Java Developers." You can take a look at the project git repo here: http://git.eclipse.org/c/epp/org.eclipse.epp.packages.git/tree/
The README file there has some instructions for building packages locally. Further questions should be directed at the EPP project directly.
Re: Easiest way to built Eclipse IDE (JAVA) on my local PC [message #1784237 is a reply to message #1784227] Sat, 24 March 2018 08:48 Go to previous message
Many of the projects have Oomph setups so that instructions similar to these can be used to set up a development environment with the sources of those projects:
https://wiki.eclipse.org/Platform_UI/How_to_Contribute/Oomph
In the end though, your goal is pretty ambitious in that many dozens of Git repositories are involved in producing something like the Java IDE package. Do you have some more specific goal in mind? I.e., what are you hoping to accomplish by doing this?
Previous Topic:Maven issues with proxy settings from a ssh file
Next Topic:Type Inference with Eclipse
Current Time: Sat Jan 25 04:46:04 GMT 2020
Powered by FUDForum. Page generated in 0.03763 seconds
