Home » Modeling » TMF (Xtext) » problem launching eclipse runtime and generating code(problem launching eclipse runtime and generating code)
problem launching eclipse runtime and generating code [message #1784110] Thu, 22 March 2018 11:46 Go to next message
Hello!
I'm new using xtext, I'm working in my DSL and found this problem when launching the eclipse runtime.
In the runtime I am able to write programs in my DLS but I can't generate code.
Does anyone know how to solve this issue?
Error:
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://509.fwk1338770454:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://509.fwk1338770454:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See url for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
Re: problem launching eclipse runtime and generating code [message #1784120 is a reply to message #1784110] Thu, 22 March 2018 12:25 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=506676
Re: problem launching eclipse runtime and generating code [message #1786583 is a reply to message #1784120] Mon, 07 May 2018 17:53 Go to previous messageGo to next message
I just joined this forum because of this exact bug. Does this mean we are doomed to not use xtext until Eclipse fixes this issue? Is this related to Windows specifically or to the Eclipse version?
This is very unfortunate as if I can't even run the tutorial, I might as well go with Kotlin instead.
Some helps or insights would be appreciate
Re: problem launching eclipse runtime and generating code [message #1786644 is a reply to message #1786583] Tue, 08 May 2018 17:29 Go to previous messageGo to next message
cant you simply ignore the warning?
Re: problem launching eclipse runtime and generating code [message #1786645 is a reply to message #1786644] Tue, 08 May 2018 17:30 Go to previous message
=> you cannot generate code must have a different reason
Previous Topic:How to let Tycho resolve dependencies in xtext-maven-plugin?
Next Topic:Help resolve this error
Current Time: Fri Jul 11 11:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.24857 seconds
